(2022-01-15, 09:17)TheGuru276 Wrote: [ -> ]Can anyone offer any suggestion on how to fix this with v2.0?
As far as I am aware, this issue has not been resolved with 2.0, but the developer of the addon was notified.
Not sure if this the correct place to ask this but here goes.
i have my films and tv shows set up in my library.
When displaying films it shows ratings from imdb,rotten tomotoes etc.
Is there a way to get the same displayed info for the tv shows as well?
Has anyone tried to vary the width (and where left they start) of panel widgets based on number of items in the widget. I have a number of widgets which have only 4 or 5 items and I really dislike the way Silvio displays them as width of widget and widget background are fixed. I have tried modding Silvio skin to do this and despite being reasonable competent at amending up the xmls I have got stuck.
I hope someone can help.
I have seen in some pics in this forum that for TV Series this skin shows if a show has ended.
I have Kodi 19.3, emby for kodi next gen plugin and latest Nox Silvo installed. I cannot see this in any Series.
Can some help me with this so I can get series status?
Hi
Need some guidance please!
Have used Silvo for some years now. Few days back with Nvidia Shield android upgrade when Kodi lost access to video files - I upgraded my Kodi to19.3 hoping it'd sort me out that problem.
Now I'm unable to install Aeon Nox Silvo skin for some reason. It says failed to install. Tried to restore data through backup - but installs with errors.
Tried to install on another Kodi on PC and then restore on Nvidia through that - no dice - Aeon nox fails to install even there (tried v19.0 to 19.3).
Am I missing something or doing something rather silly? Any help appreciated.
The skin has a small bug as described
here.
Is there any way to show filesize in this skin, if not could it be a possible addition?
Many thanks, great work.
install latest NVidia Shield update (hotfix 2) ... if nothing gets fixed update to kodi 20 alpha...
thank you
i see that the last post of metadata editor is from 29/9/2021.
I removed metadata editor and error message was gone
(removed script.metadata.editor folder)
I would like to use widgets for my tv shows and movies.I only want one for each.Both showing all the library. I can find settings for Recently Added or In Progess etc but not for the whole collection.Anyone help me with this?I must be missing something obvious.
select widget - video library - movies - titles
same with shows.
