Hi Mike Fix is working!!! Thx... Do you know what name must be in the title of the movie so it loads the blu-ray case?
I am working on Pulsar strm files.
Or is there a way to set the Blu-Ray case as default <----- now iets the red one
(2015-03-26, 23:34)Warez Wrote: [ -> ]Hi Mike Fix is working!!! Thx... Do you know what name must be in the title of the movie so it loads the blu-ray case?
The cases are populated by the video resolution infolabel in the database. If you want to have cases the item must have that infolabel available. The red clearcase is shown when no resolution information can be found which is usually a movie set or certain unplayed items that do not have that information when adding it to the library like iso files. I am not sure if playing the strm file will work in this situation, but you can try asking the addon developer to include the infolabel if it is possible to do so.
Oke is there a way i can make the infolabel my self or can i set the Blu-Ray case as default ? so it loads the Blu-Ray case if no resolution information can be found?
Its for a raspberry pi so... i only use strm files
(2015-03-27, 00:22)Warez Wrote: [ -> ]Oke is there a way i can make the infolabel my self or can i set the Blu-Ray case as default ? so it loads the Blu-Ray case if no resolution information can be found?
Should work if you replace the p.png image in media\thumbs\boxes\clearcases with the 1080p.png one but you will lose the movie set case if you do.
I can sent you a image of my build if want...
Does anybody know when or how the trailer button is activated in the extended info script Movie widgets?
Some movies you can click on the button... some are greyed out... i think it's a scraper thing but don't know what to look for?
After reinstalling my System , the ratings are gone
On my previous installation the FSK Ratings worked fine with your skin .
TV-Show rating working , but i got no Movie Rating ( i also tried to get MPAA ratings but it dont work)
autostart in the configfiles folder... and in the 2 kaitoast files 1080i folder
Mike, I have been using XBMC for a few years, now KODI, and have never really messed with customizing any of the skins or fooling with any mods. I have Kodi running on 7 different Firesticks and really love how this tricked out skin looks. How difficult is it for someone with limited experience to set them up the way it is in some of the images in this thread?
(2015-03-27, 14:49)Purge Wrote: [ -> ]After reinstalling my System , the ratings are gone
Do you get no rating or NR as the rating? I recently had a similar issue and the problem was the rating prefix in the scraper settings. I changed it to be Rated with a space at the end and it started working for me with MPAA ratings. I think that will work for FSK ratings but if Mario S. pops in I am sure he can confirm that or help if I am mistaken.
(2015-03-27, 21:18)mateus Wrote: [ -> ]Mike, I have been using XBMC for a few years, now KODI, and have never really messed with customizing any of the skins or fooling with any mods. I have Kodi running on 7 different Firesticks and really love how this tricked out skin looks. How difficult is it for someone with limited experience to set them up the way it is in some of the images in this thread?
If it is too difficult I definitely did my job wrong
The setup should be as easy as selecting the options in skin settings. I made a tiny FAQ that is still in progress but maybe question 4 and the following answer will help you
Click Here to see the FAQ. If you still need help just post what you want it to look like and either myself or someone else will point you in the right direction. Happy customizing!
Just so I don't waste time looking for a ghost, are all the images for movies and TV that appear as backgrounds and sliding DVD cases part of the mod or zip file? Or is that something that has to be created by me?
