(2017-01-25, 00:15)Botafuco Wrote: [ -> ] (2017-01-24, 01:48)style2k Wrote: [ -> ]i just installled this skin,, looks verry promising .
but i have some problems ,, i am customising the backgrounds for the menu.
but i can only sellect certain backgrounds.. i found the weather background after installing weather art pack thingy.. but i also installed some other backround art packs ,, wich work in other skins, but cant i choose fro those packs ? stil need some background for settings end few other menus.
so how can i use those background art packs in the menu
Style2k, go to system, then appearance, then skin, then settings, then go into "setup aeon nox main menu", there you can choose the backgrounds for each menu.
Choose "select background" and use accordingly. For the weather menu, choose "conditional weather" and you should be able to chose from the weather art packs you downloaded.
I hope this helps. Cheers.
yes what you said i did already like i said i fond the weather backround,, but my question was how can i use the normal skin packs to choose a background from? now i only can have preentred images like movie fanart etc, and single image but then i have to browse a folder..and i wanna use some backgroubds from skin packs and i dont see them in backgrounds..
problem with fast scroll down:
when i see iptv and i show my playlist, i can't scroll down fast ( like you can press right and scroll down every page, and not one by one )
(2017-01-25, 13:49)robertus Wrote: [ -> ]problem with wallpaper:
when i want to select a wallpaper, i can't select download folder where i have my backgrounds.
Why?
Map to that folder in Kodi File Manager then select that mapped folder?
(2017-01-25, 13:50)martinconroy Wrote: [ -> ] (2017-01-25, 13:49)robertus Wrote: [ -> ]problem with wallpaper:
Why?
i do add source and i solve it.
but i have an issue with fast scroll down, i edit my previous message
thanks anyway for the support
this skin turns out to be a disaster. first of all subs not working.. i have to manualy turn em on while there is already a sub there besides the file, second sudenly without any reasy in my navigation my movies selection is gone even thought it is turned on in the settings.. and when i use recently added show whole of kodi crashes..and it also fucked up all my other skin settings
?? also reset skin settings doesnt work.
(2017-01-25, 16:02)style2k Wrote: [ -> ]this skin turns out to be a disaster. first of all subs not working.. i have to manualy turn em on while there is already a sub there besides the file, second sudenly without any reasy in my navigation my movies selection is gone even thought it is turned on in the settings.. and when i use recently added show whole of kodi crashes..and it also fucked up all my other skin settings ?? also reset skin settings doesnt work.
Maybe you should re-read the first few posts and make sure you have the proper version of the skin for the version of Kodi you are using. 1000's of people use this skin everyday with minimal issues....think about that. You want help yet you post NO debug log file for the Great and Mighty Silvo to review and try to help you. So...want help, post the log file....or just use another skin of your liking.
When you see iptv and show your playlist, like press OK, then playlist botton that show your channels, you can't scroll down or up fast, if you press right or left, make a glitch and doesn't change the cursor to change fast page.
how can i fix it?
(2017-01-25, 00:25)style2k Wrote: [ -> ] (2017-01-25, 00:15)Botafuco Wrote: [ -> ] (2017-01-24, 01:48)style2k Wrote: [ -> ]i just installled this skin,, looks verry promising .
Sorry if I misunderstood you earlier then. I don't know if I can help you further, I'm not sure what "skin packs" are. Is it possible you are looking for a feature this skin doesn't support?
Hi guys, I've recently been using Aeon Nox 5: Silvo skin which is brilliant but I've run into a lil problem with which hope someone can help me with...
I've recently installed this skin on 2 Android boxes but having trouble with the widgets which is doing my head in lol...
I'm trying to click on widgets 1 and nothing happens, tried clicking widgets 2 and still nothing happens?
I've tried this skin on 2 android boxes from a fresh Kodi install (Box 1 running Android 4.4 & box 2 running Android 6.0.1) and it still doesn't work, so I installed Kodi on my phone, installed Aeon Nox 5: SiLVO and tried adding widgets and it works?
I'm confused... I'm using Kodi 16.1 Jarvis on all...
Why is it that when I try to add the widgets on the boxes nothing happens but on my phone it works flawlessly... what am I doing wrong?
Hope someone can shed some light to my problem it'll be most appreciated.
(2016-12-14, 02:24)mikeSiLVO Wrote: [ -> ] (2016-12-11, 19:02)Botafuco Wrote: [ -> ]Hi Mike,
I do not have "service.skin.widgets" installed.
I went through the crash logs and I noticed that one of the last things Kodi was "doing" before crashing had to do with "script.tv.show.next.aired". So I disabled this addon, and I haven't seen Kodi crashing since then. I haven't done exhaustive testing, I just used it like I normally do for a week so far.
Do you, or anyone else, have the Next Aired addon running? Has anyone experience any crashes?
EDIT: Nevermind, it crashed again...
I don't really konw what to test. I never had this problem before the last skin update, and I haven't changed or added anything. It has to be skin related because I don't have this problem with Confluence, and that I have given a good test before.
I have next aired and I do not have any more crashing. Skins like Confluence and Estuary don't use any addons for their menus so they cannot be used as definitive proof that it is a skin issue. Nothing I have updated should be able to affect entering a library item and specifically only TV Shows is especially weird. I see no one else experiencing the same so until I get more users posting, I will have to assume it is an issue with your system so try backing up your userdata (wiki) and starting from scratch with a new install.
Hi Mike, I got some feedback for you on this weird issue:
Kodi rebooting when entering the Movies/Shows sections
-I reinstalled everything from scratch, LibreElec, Jarvis, Raspberry Pi 3.
-I restored the database backup ONLY (using the Backup addon, such great addon, and then Watchlist).
-Basic setup, nothing crazy, bare minimum required addons and services.
-Everything worked fine for a whole week.
-I then added Artist Slidehow and Keymap addons.
-Almost immediately, the issue appeared (!)
-I removed the Artist Slideshow addon.
-The issue went away (!) (or at least it hasn't happened for almost a week now -knocking on wood-).
I don't know how, but could Artist Slideshow be causing the issue? I don't know anything about skinning, so I'm not sure the addon is related to movies or shows?
hi i am a little newbie to kodi and i tried to search my problem but didnt find anything . i ve installed aeon and it seems that when i try to see informations for a movie it doesnt work . while changing back to my old skin it works fine . i get something like " could not find item at moviedb" i ve created an acc to that site cause i thought that was the problem but still get the same error .
thank you
(2017-01-26, 02:34)horizonx Wrote: [ -> ]Hi guys, I've recently been using Aeon Nox 5: Silvo skin which is brilliant but I've run into a lil problem with which hope someone can help me with...
I think it's a known issue...but...I just hook up a keyboard, use the arrow keys and the enter key
Mouse clicks just don't seem to want to work there. It's funny but touches do work on my tablet. The IR remote that came with my UT2 Ugoos boxes worked too (arrow buttons and OK button)....it's a mouse thing, no cheese
(2017-01-19, 12:18)heula Wrote: [ -> ] (2017-01-17, 22:42)heula Wrote: [ -> ]Playing around with this skin and used to titan skin I see a few things I miss in this skin comparing with Titan..
language flags for subtitles and Dutch mpaa rating icons. I downloaded a flag addon but It is not visable. is this already supported?
kodi jarvis 16.1 in use with Aeon Nox Silvo and myflix view.
thanks
I will likely not add flags as I do not like the look of them but never say never... Though, in this case, never is realistic...
Can you make it optional so I can choose to add it myself?
Or perhaps something like "DUT' ËNG" instead of flags?
You did not answer my question about the Dutch MPAA ratings. Is it possible to have country related ratings. In my case that would be NL-AL, NL-6, NL-9, NL-12, NL-16 and NL-18.
Dutch mpaa ratings
(2017-01-25, 23:36)Botafuco Wrote: [ -> ] (2017-01-25, 00:25)style2k Wrote: [ -> ] (2017-01-25, 00:15)Botafuco Wrote: [ -> ]Style2k, go to system, then appearance, then skin, then settings, then go into "setup aeon nox main menu", there you can choose the backgrounds for each menu.
sorry my bad i mean art packs like the weather art packs,
Gallery view is really nice but it takes backdrops as an image to view. Is it possible to let it take the thumb image without loading the logo in it? Thumb images alraedy have an logo (Title) in it.
Or make this optional so people can choose them selves what they want?
Is it also possible to have a border around the thumb in myflix view. The selected episode is now only brighter than the others but a nice border would be nice.
