(2023-11-03, 06:17)mikeSiLVO Wrote: [ -> ] (2023-10-30, 18:12)brazen1 Wrote: [ -> ]Thank you @mikeSiLVO !
Your update to TMDB helper integration fixed stuff that has been bugging me using Kodi v21. Much better now.
No problemo
Let me know of any other issues you notice. I am hoping to fix anything and everything before Omega release
Don't mean to nitpick the best skin imo but here's a few:
(1) Skin settings/Main menu/Setup the Aeon Nox main menu
Skin settings/Customization/Setup the Aeon Nox main menu
are the same thing. Should this setting be listed twice?
(2) Does tv show next aired work for you? I have it installed and Skin settings/Extras/Enable Next Aired information in the videolibrary is enabled. When I go to Skin settings/Main menu/Setup the Aeon Nox main menu and select TV SHOWS (a main menu item) in the left column, then to Select Widget 1/Select Widget/Add-ons/Program add-ons/TV Show Next-aired... the 'EDIT TITLE' virtual keyboard is presented. Doesn't matter what is typed. Next the 'Select widget' window is presented again. In other words, nothing happens. No widget appears on the main menu. Somehow I linked a shortcut to it in my TV SHOW submenu. Clicking it does nothing.
(3) In the movie library, select Information and scroll down to actors pictures. Select one and choose Online information from TMDB. Scroll down to Image Gallery and select a picture. A fullscreen window appears with nothing but the enlarged picture. There are two problems here. 1st, the picture does some weird panning and refreshes it itself rendering a black screen after a few seconds and repeats the process. I don't notice this every time... just sometimes and I don't know the conditions. Imo, it should be static. 2nd, many moons ago you could select the next picture of the actor by pressing the left or right direction arrow keys but they don't do anything anymore.
(4) Select Information for a movie title. Scroll up to the PATH:. The path can be long and there is not enough text room to display it fully so I have to select it. The path is not overlayed in text anymore such as Filename: is. Instead, a new window opens with a blank poster, a fanart, and a couple of stats - sort of like if you selected a Movie set and landed on one of the titles except it isn't anyway near as feature rich. Nothing about the path either.
(5) In the movies library, lower left are the ratings icons with values. Some of them display the TMDB rating icon. This same (I THINK) value is already displayed above the synopsis in text along with the number of votes. So, the TMDB icon/value in the lower left is sort of worthless. Upon further examination, the rating/value/votes above the synopsis is different than the TMDB icon/value in the lower left of the bottom bar. What setting determines who is rating the rating/value/votes above the synopsis because now I'm not sure if that's TMDB? Perhaps I'm using a conflicting setting somewhere...
Also, only some titles display this TMDB icon on the lower left next to the Popcorn hour audience icon/value for example. Other titles have no TMDB icon at all. Instead, they display the Tomato critics icon/value and a Popcorn audience icon/value for example. Still, other titles display even more different icons/values and combinations but are always limited to only two in the bottom bar on the lower left. It all appears sort of messy. I think all the ratings should appear. If some of them don't offer a rating for a particular title, then they simply shouldn't appear. It just seems random what displays and what doesn't.
Why is it titles display erratic choices of who rates what? Can more than two ratings display by making them smaller and cramming them together... one on top of the other or closer together for example? Personally, choosing to eliminate STUDIO icons/text as a settings choice preference could create more room also. The value text next to the rating icon doesn't need to be so large and maybe that could accommodate more room. Also, eliminate TMDB since it's already above the synopsis (I THINK) and shows more value (votes and percent) than the icon/rating in the lower left which only shows percent.
Fwiw, I'm using the MyFlix view. I hope you can duplicate my words without a bunch of screenshots.
