(2016-01-22, 12:21)Mr. V Wrote: [ -> ] (2016-01-22, 08:46)junias Wrote: [ -> ]Hi there!
Thanks so much for the skin, it looks really good!!
Yesterday i´ve updated to jarvis rc1 and of course to nox.silvo 3.0.1 for jarvis
Everything works as expected, really nice skin. And i really like the new jarvis function to customize widgets and so on
But i´ve got two questions:
1. Is it possible, in the kino widget, to direclty show the rating? In Isengard beneath the widget the movie name AND the imdb rating was shown, i think in jarvis this isn´t possible...
2. Is there any option to speed up the skin? I´ve got an i3 with 2gb Ram on Windows 10 32bit and the skin is sometimes really laggy (home menu, scroll through lists, ...) or even completely hangs up (starting a movie, watching live-tv and switch through channels)... I already disabled all views i don´t need, now i´ve 5 views activated... and i already enabled the kiosk mode, but in my opinion both didn´t work...
Thanks for your help!!!
Hi Junias,
1. Not sure ATM. I am quite busy with widget coding so after the update within a week or two i could take a look then. If you still have any issues please remind me after the update.
2. Sounds a bit strange that you are having issues. As i understand people can run this on there Pi that has lower specs and works quite well. I assume this is not a fresh/clean install.
But here are some things to keep in mind or to try in order of most importance; (really number 2 should be first place and 3,4 and 5 are not always the best solutions but i like to think of them as the last resort, anyway just a guess at what you could try since you have not provided a debug log)
1. Downloading then Pasting the GitHub download over the top of the existing silvo skin folder will break things (things change and get removed and left over files screw your install)
2. PROVIDE A DEBUG LOG SO WE CAN SEE WHAT IS SLOWING YOUR SYSTEM DOWN
3. Reset your main menu
4. Delete and rescan your database
5. Try a fresh install of kodi
If I had to guess about any performance issues then it might be similar to Shinoby92 and the player control problem they have... If you use streaming add-ons they may be poorly coded and use up all the resources of a process thread blocking things for a moment. If I am not mistaken, Krypton moves playback from the main thread to it's own so you both can try the latest Kodi v17 Krypton, but if it helps...
(2016-01-22, 14:21)Alanon Wrote: [ -> ]@mikesilvo164: I noticed that you are experimenting with the handwritten font for the CD visualisation. I hope that you will consider some font besides fafers and the new experimental one, since they basically don't work in any language other than English, and that can look anything from weird to plain ugly when displaying Cyrillic letters or even accented Latin script. I realise that it's a huge bother researching this issue, but since I generally need these kinds of fonts in my computer use, I've found three fonts that strike a good combo between looking like nice handwriting while supporting most European languages (Gunny Rewritten, Pecita Font, and Occupy). They all seem to be free and in the public domain.
I hope you find this useful. Cheers!
I used one for the lyrics, test it if you can, but do you have any others to pick from for the CD labels?
(2016-01-22, 14:36)RavRob Wrote: [ -> ]Hi all
I'm trying to get the same view on all my different tab, submenus etc. I like the side list but it seems I have to set it for every tv shows individually and even in each seasons as well.
I might very likely be missing something in the settings. If someone could point me to the settings for that.
Also, I'm having problems with my sub menus. I have set up in my picture main menu. a sub menu for "Flikr's interesting" today and a couple of others. If I select the sub menu directly, it plays well, but if I select the main tab to see all the sub menus items I have, I get a blank page. I tried to change action for the main tab but really not sure where I should point it to see all my sub menus items when dealing with addons.
Try deleting viewmodes.db in the
userdata (wiki) database folder and re-selecting the choices for your views. For the menu issues post your script-skinshortcuts-includes.xml file so I can see what your path for the Main Menu item is but clicking the Main Menu item should not open a list of your added submenu items automatically...
(2016-01-22, 18:31)martinconroy Wrote: [ -> ]Hi,
Random question ... I'm using Advanced Launcher to set up games, but when browsing the directories I can't see any EXE files. They are visible using Confluence, so I'm assuming there's a specific skin setting somewhere, but I can't spot it. Any ideas?
I don't use Advanced Launcher so if you can post some screenshots of what works in Confluence but does not in this skin, it would be very helpful
(2016-01-22, 20:24)Solo0815 Wrote: [ -> ]@mikesilvo164:
as you are "playing around" with music fullscreen, think about adding this additional view:
http://forum.kodi.tv/showthread.php?tid=245129
At the moment it is unlikely to be included since you can add the mod yourself if you prefer. Might re-visit after the next repo push but for now...
Hello fellow Kodi enthusiasts
I want to ask those that use the latest versions of the GitHub skin, if you would like to share some screenshots of your favorite color scheme using your favorite views... It is time to update the album images in the first post and I thought I would ask the users to show off what they like and use
Any images from
this skin are welcome but only if they do not contain images of, or include references to, any current or possibly added in the future
banned add-ons (wiki)
If posting images please use
http://imgur.com/
well because of your 2.
windows 10 as a base and "just" 2GB ram - it seems this could be your bottleneck ! - ram is so freaking cheap ... put in at least 4GB ram ( better 8GB not so much more expensive )
i have a AMD A6 Tricore APU with 8gb ram and a SSD HDD ... and i would say its running realy smooth - i have some small delay when i scroll fast! through my movies and showcase/poster/shift view, but its not realy bad
but 2GB for WINDOWS and kodi is realy a bit low...( M$ say you need at least 1GB ram for win32 version - +Kodi... )
i have running even MADNOX on my Rasperry Pi2 and the navigation is smooth there too ( with 1GB ram, but Openelec as OS ) - i have some other problems because of the low hardware, but navigation+ playing stuff is realy nice and smooth
and you need to configure your windows 10 ... disable everything you dont need ( windows 10 have a lot activate by default ... go through all windows settings and have a look )
and check your services ... disable also every service you dont realy need ... with this small tweaks you can archive a smoother navigation too
but end of story - buy more ram and maybe a ( FAST ) ssd hdd ( also cheap right now ) = much more fun
greetz
hi i am trying out this new version on this skin on jarvis and isengard and what i am find is that when you go to setup the skin there are some things that do not show up on the main menu bar like live tv and weather , is there a bug ? as cannot see how to enable then so it show on the main menu thanks for your advice
(2016-01-23, 16:32)flowerpot Wrote: [ -> ]hi i am trying out this new version on this skin on jarvis and isengard and what i am find is that when you go to setup the skin there are some things that do not show up on the main menu bar like live tv and weather , is there a bug ? as cannot see how to enable then so it show on the main menu thanks for your advice
you need to download some icons from REPO - look and feel ... icons, weather icons, weather fanarts, studios etc...( just JARVIS ! )
I think you need to have a Live TV backend active and Live TV enabled in Kodi settings.
For weather, pretty sure, you also need to have a weather addon enabled in order to satisfy the visibility conditions that are automatic for skinshortcuts.
System > Add-ons > Install from Repository > Kodi add-on repository > Weather
How does one refresh a movie in this skin? Usually in Nox I would pull up the info screen and simply hit the refresh key and it would ask if I wanted to refresh locally or from the scraper. I can't seem to find this anywhere in this version. thanks!
Hi using Aeon Nox (Love your work) and have a complete build with pictures and subtitles. I can see it saved my addons and programs however my Custom menu, Subtitles and pictures are not showing up.
I've tried USB wizard restore, Full restore brings me back to old version but then Aeon Nox will auto update and I lose them again.
Rob
[email protected]
P.S Just adding this . I'm using an android box and
When I go to set up example TV shows. . Select background.
.Multi image - There is no choice for external hard drive just Repos?
(2016-01-19, 21:06)Mario S. Wrote: [ -> ] (2016-01-19, 20:37)dannyau Wrote: [ -> ]Krypton ver on OpenELEC works fine except colored icons/flags.
I couldnt install from zip,so just unzipped to addon dir.
Do I need to dl anything else manually to get color icons?
did you downloaded the new resource.images from the addons in look and feel
I got it working now,thanks.
What about animated whether icons?is there a way to make this works?
I dl the pack,enable animation icons in whether settings and nothing shows.
(2016-01-24, 05:50)exoscoriae Wrote: [ -> ]How does one refresh a movie in this skin? Usually in Nox I would pull up the info screen and simply hit the refresh key and it would ask if I wanted to refresh locally or from the scraper. I can't seem to find this anywhere in this version. thanks!
That depends on the skin options you have chosen... Can you be more descriptive of the the settings you have activated and what you are seeing?
(2016-01-24, 08:36)Robzilla Wrote: [ -> ]Hi using Aeon Nox (Love your work) and have a complete build with pictures and subtitles. I can see it saved my addons and programs however my Custom menu, Subtitles and pictures are not showing up.
Rob
[email protected]
#1 Stop PM'ing me
#2 I do not care about your "build" cause that, to me, just means you have read articles on the internet and expect me to help you solve issues related to using your shitty piracy add-ons and repos.
#3 Only having choices of "repos" means you have done exactly what I think you did was just read something on the internet and add some repos as a source...
#4 If you try using the skin and Kodi as it was meant to be used, and have issues, then please report them otherwise... Deal with it yourself or contact the ones who provide the repos and add-ons you have installed.
#5 If I am wrong then post a
debug log (wiki) of your issues and then I will see that you do not have any
banned add-ons (wiki) and repos installed on your system.
I DO NOT SUPPORT OR PROVIDE ASSISTANCE TO ANYTHING RELATED TO STREAMING ADD-ONS AND CRAPPY REPOS. I HAVE ENOUGH ON MY PLATE SUPPORTING THE SKIN AS IT IS.
(2016-01-24, 15:25)dannyau Wrote: [ -> ]I got it working now,thanks.
Animated weather icons would require a redesign of the weather section so that is not likely to happen by me. If anybody has any interest they can use the images in the resource add-on and make GIF's of them and then replace the icons used to show the weather icons with those GIFs.
(2016-01-24, 16:05)GTunney Wrote: [ -> ]Mike, I'm more than happy to take some shots for you but I'm only running latest isengard GitHub. I presume you want Jarvis shots?
Anything GitHub Isengard and up so feel free to post away
(2016-01-24, 16:08)mikesilvo164 Wrote: [ -> ] (2016-01-24, 16:05)GTunney Wrote: [ -> ]Mike, I'm more than happy to take some shots for you but I'm only running latest isengard GitHub. I presume you want Jarvis shots?
No probs. Will wait until kids have finished watching Mrs Doubtfire then grab some for you.
Who reads this thread that I should blame for my Ed Sheeran addiction? Probably someone from the UK...
Little perspective, I grew up listening to rock and metal music and my favorite band of all time is Guns N' Roses...
Which one of you should get blamed for this?
