(2021-03-06, 07:43)brazen1 Wrote: [ -> ]I see an add-on called Next Episode but not sure that's it? Also if you know the widget name that would be great. Thanks for sharing
I'm going to post in this reply a small tutorial about "Next Aired" and "Next Aired Widget" for all you guys recently migrated to Kodi 19 "Matrix".
1. Check you have all needed dependencies installed (this varies from skin to skin, so I would be focusing in "Aeon Nox Silvo ")
* Go to "skin settings" -> Help -> Install or change settings of supported add-ons
* Install all "required" and the following "recommended": Skin Info Service, TheMovieDb Helper, Ebuary Info, Embuary Helper
2. Enable Next Aired information by turning it on: Skin settings -> Extras
Note: You can get "Next Aired" via 2 addon programs: "The Movie Db" and "Embuary Info (uses The Movie Db). The difference is "presentation"
Now, go to both programs and explore them. Check differences and options. Decide with one you like best and offer you the most.
Now we are going to create a submenu for ALL TV SHOWS AIRING IN YOUR LIBRARY and a widget that shows you ALL TV SHOWS AIRING WORLDWIDE (you can interchange them or only make one or choose other options, which ever best suits you).
3. Go to -> Skin Settings -> Main menu -> Setup the Aeon Nox mein menu -> TV Shows -> Manage submenu -> Choose item for menu
On the window now we choose -> Add-ons -> Video add-ons -> Embuary Info -> "Trakt.tv - Next airing episodes of your TV show library" -> Next 7 days -> Create menu item here
4. Set your desired label and if you feel up to it, your prefered background.
5. Press back
Now we set up the widget
6. Select widget 2 (for lower position) or widget 1 (higher position)
7. -> Select Widget -> Add-ons -> Video add-ons -> The MovieDb Helper -> TV Shows -> Airing Today -> Use as widget
8. Press back till you are on main menu
You should have something like this:
SUBMENU
NEXT AIRED INFO
The next aired information you can customize like any other library view in Silvo. This is the default, but you can change it to Lowlist or Rightlist. Each one offers different info to display. And like any other item in your library, when you press "info" it will display the appropriate info.
Here I just posted the process for one kind of information mined from the add-ons, but the possibilities are endless.
I hope this quick tutorial is of help. Have a great day everybody
