(2021-11-23, 07:53)Jeffers24 Wrote: [ -> ]Is this a bug in skin shortcuts module 2.0.0 that will be fixed in a future updated version, or do I need to make the successful changes that flhthemi made?
Am I best waiting for a fix or making the changes?
Why wait...all you have to do is just select the widget poster type. I think what has happened is that the update missed grabbing that particular setting when it updates. Mine has been working as intended since I made the change.
Hi all
I've just spent some time combing through this thread trying to see if RightList view has been fixed yet (i.e. to get it to "stick" and not keep reverting to List view) but can't find anything. Does anyone have an update on this?
(2021-11-24, 07:17)Maddcow Wrote: [ -> ]Does anyone have an update on this?
It's working perfectly fine for me:
Aeon Nox 8.0.1
Windows 10 21H2 ( and Windows 11 too)
Kodi -19.1, 19.2 and 19.3
(2021-11-25, 05:03)lynxstrike Wrote: [ -> ] (2021-11-24, 07:17)Maddcow Wrote: [ -> ]Does anyone have an update on this?
Hmm, ok. Every time I set RightList as the default view, it reverts to List and it's driving me nuts.
I really wish there was a way to set a default global view for TV shows that applied to Show list, Season and Episode. I much prefer RightList or TriplePanel but if I want this view, I need to apply it to every single show, season and episode. Such a pain in the a$$.
If not done already, try setting views in the tools section of the addon you are using.
(2021-11-23, 16:06)flhthemi Wrote: [ -> ] (2021-11-23, 07:53)Jeffers24 Wrote: [ -> ]Is this a bug in skin shortcuts module 2.0.0 that will be fixed in a future updated version, or do I need to make the successful changes that flhthemi made?
If it's a bug I would rather wait for the fix as 10 day and hourly views are working fine.
If it's not a bug and the only way to fix is the changes you shared
I would make the changes
Question regarding font in list view. Is it possible to change that font size?
Sometimes if the file name is larger its in two lines, then those lines are over each other so its difficult to read.
Thank you
Hi guys! I've lost the "settings menu" on the main menu... So I can't access to skins settings... [emoji51] Is there another way to do it? I want to change the main menu again and I can't [emoji53]
Thank you!
(2021-11-28, 11:53)Joaquin_Barrera Wrote: [ -> ]Hi guys! I've lost the "settings menu" on the main menu... So I can't access to skins settings... Is there another way to do it?
Press
s on your keyboard. It will be one of the options in the list.
(2021-11-28, 12:03)Karellen Wrote: [ -> ] (2021-11-28, 11:53)Joaquin_Barrera Wrote: [ -> ]Hi guys! I've lost the "settings menu" on the main menu... So I can't access to skins settings... Is there another way to do it?
Press s on your keyboard. It will be one of the options in the list.
Thank you mate! It was driving me crazy! Was eaaaasy [emoji23]
Im looking for a way to show the episode number on the osd / seekbar.
By default only the EP title is shown or additionally the chapter, if present, which should be replaced with the number.
Hi, I can not search original movie title in English. No result. Title of the movie only in my national language displays result. Is it normal? Maybe some option is not checked? Regards.
(2021-12-15, 12:36)BlackJack1 Wrote: [ -> ]Hi, I can not search original movie title in English. No result. Title of the movie only in my national language displays result. Is it normal? Maybe some option is not checked? Regards.
Press "C" or right click title.
Select Manage.
Select Edit Title.
Type the name of title you want.
Save.
How to keep the Music OSD always on, and/or change the visualization by another ?
Issue: SubMenu "single image" backgrounds not showing if me main menu has live background.
Situation:
- I have 7 sub-menu items under "TV".
- TV main menu has live playlist background
- 5 of the sub menus have different live playlist background
- 2 of the sub menu items have different "single image" backgrounds
- the main menu and 5 sub menu live backgrounds all work fine; neither of the 2 sub menu "single image" backgrounds show up
- when I go into one of the 2 sub menus with "single image" backgrounds, for a brief moment, the background image shows up (so kodi / aeon nox definitely "see" the image in the setting)
- I have the same issue with the Movie main menu with live backgrounds and its sub menus that have "single image" backgrounds do not show
Details:
- Latest version of Matrix on NVIDIA Shield TV Pro
- Previously happened on Leia on Intel / LibreELEC
