Have decided to change my amateur build from CCM Helix to Nox 5 Silvo could somebody point me to which settings file contains the backgrounds data (in the Jarvis structure) whereby I can do the Special:// ........ detail to allow build to be used on multiple platforms... thanks in advance
(2016-02-25, 23:13)Buzzsaw Wrote: [ -> ] (2016-02-22, 17:32)Buzzsaw Wrote: [ -> ]Can Video Extras be used at the same time as Extended Info on the Movie Info screen? It seems I can only have one or the other. If Extended Info script is running, there is no way to access the Video Extras that I can find. Ideally, I'd love to have Extended Info running and then have Video Extras show up in the "+" option. Can that be done? I guess I'd also like to have "Trailer" added to the "+" option too...
Can anyone help me with my question on accessing Video Extras while also having Extended Info running? If I would have to do this mod myself because no one else wants it, can someone tell me the relavent files to mod to add these to the "+" menu?
I do not think that this can be added to the + menu, I believe it is handled internally by the Extended Info script so maybe it can be requested as an addition like the Artwork Downloader entries... I have added some things from the Extended Info panels into the default info already, besides the TMDb integration is there something missing you would like there?
(2016-02-26, 03:52)villano666 Wrote: [ -> ]Hi, I've updated to Jarvis and my resolution crashed after update, It´s huge and I can´t even see the menu to make changes. How do I fix this?
I don't see how the skin could cause this but deleting your guisettings and resetting up Kodi is your best bet. If you feel adventurous you can try deleting the entire <resolutions> section from guisettings.xml when Kodi is not running.
(2016-02-26, 14:34)ZD5B Wrote: [ -> ]Hi MikeS
In skin settings TVShows.. select background..(video playlist) TV Show works on Iseng. but not on Jarvis its not even listed.
Also weather icons dont show on main weather screen (works on Iseng) not Jarvis
Have DL from 1st page repo+update
Is it a Jarvis thing or do you know what the problem is and your working on it. Main PC is on Jarvis and laptop is on Iseng.
Weather icons work just fine and if you mean fanart then you need to select the fanart pack by selecting Backgrounds from the side menu in the Weather section. Choose get more and select the Weather fanart multi.
I am not sure what you mean with the TV Show playlist backgrounds... The code used to display them are the same across all versions besides Helix.
(2016-02-26, 15:12)mjwsparky Wrote: [ -> ]Have decided to change my amateur build from CCM Helix to Nox 5 Silvo could somebody point me to which settings file contains the backgrounds data (in the Jarvis structure) whereby I can do the Special:// ........ detail to allow build to be used on multiple platforms... thanks in advance
Please don't
just stick with CCM
(2016-02-26, 05:23)villano666 Wrote: [ -> ] (2016-02-26, 04:43)flhthemi Wrote: [ -> ] (2016-02-26, 03:52)villano666 Wrote: [ -> ]Hi, I've updated to Jarvis and my resolution crashed after update, It´s huge and I can´t even see the menu to make changes. How do I fix this?
What hardware are you using? Android or PC or RPi?
Hi, it´s a pc
Not sure this will work, maybe someone will tell us
Look in guisettings.xml for these lines:
<window>
<height default="true">480</height>
<width default="true">720</width>
</window>
<resolutions />
If they are the same do nothing it probably won't work to change them. But if those numbers are larger edit them to 480 and 720 and see if that gets the job done.
Hi, I've fixed resolution problem but now that I've updated Silvo I've lost all my settings. Any ideas how to get everything back?
Also I'm having problems watching this through remote desktop (I've do some configurations remotely sometimes) and it always worked fine until now. I can´t see anything it's a blank screen when I turn on kodi. When I go through HDMI it works fine
Does anybody know how to move the widget to the bottom..?
.... need to know the xml file... and line....
(2016-02-27, 02:53)Warez Wrote: [ -> ]Does anybody know how to move the widget to the bottom..?
Widget 2 is always at the bottom of the screen and Widget 1 is always centre of the screen for the vertical menu.
or in Includes_Widgets.xml - line 13 change the slide animation and line 48 for widget 2
<animation effect="slide" end="215,-64" condition="StringCompare(Skin.String(MainMenu.Layout),$LOCALIZE[31994])">Conditional</animation>
I updated to Jarvis and now the skin doesnt work. No mouse pointer and eveything lags so much that it impossiblee to do anything.
EDIT: I should learn to look at 1. post before I post. Just found the Jarvis version.
So about multiple widgets. Currently, I am unable to get two to show up on either Movies or Television. Only Widget 2 will show up. However, I am able to add 2 widgets to my Videos(In Progress and Recently Added). So are Movies and Television just limited to 1 Widget these days? Not a deal breaker but I would love the flexibility to be able to do this for my Movies and Television.
Thanks again! Loving the updates!
(2016-02-27, 22:34)Elfman Wrote: [ -> ]So about multiple widgets. Currently, I am unable to get two to show up on either Movies or Television. Only Widget 2 will show up. However, I am able to add 2 widgets to my Videos(In Progress and Recently Added). So are Movies and Television just limited to 1 Widget these days? Not a deal breaker but I would love the flexibility to be able to do this for my Movies and Television.
Widget 1 and 2 works for all menu items. You could try resetting the menu item or send me a copy of script-skinshortcuts-includes.xml in the 1080i folder.
(2016-02-27, 23:19)Mr. V Wrote: [ -> ] (2016-02-27, 22:34)Elfman Wrote: [ -> ]So about multiple widgets. Currently, I am unable to get two to show up on either Movies or Television. Only Widget 2 will show up. However, I am able to add 2 widgets to my Videos(In Progress and Recently Added). So are Movies and Television just limited to 1 Widget these days? Not a deal breaker but I would love the flexibility to be able to do this for my Movies and Television.
Strange. Recreating the menu, deleting the old one, renaming seemed to work just fine.
Thanks for the help!
Stats are fun! Stats are fun, right?
Since I started keeping track:
- Repo has been downloaded 14,112 times.
- Skin downloads on the first page average around 1,000 a month, per version, so a little over 2,000 total.
- GitHub page gets 650 - 750 unique visitors every 14 days.
(2016-02-28, 03:45)mikesilvo164 Wrote: [ -> ]Stats are fun! Stats are fun, right?
Since I started keeping track:- Repo has been downloaded 14,112 times.
Mike it's just a reflection of the hard work and dedication yourself and everyone else involved with Aeon Nox Silvo has put in.
When people see my setup they always ask which skin I use and I always reply the same thing. "Aeon Nox Silvo, the best and only skin that should be used with Kodi"
Congratulations on your success and may it continue for a long time to come.
Thanks for the Skin! I love it!
Yesterday i updatet Kodi from Isengard to Jarvis.
I also updatet Aeon Nox Silvo to the newest Jarvis version from Githup.
Now i have the problem, when i try to change backgrounds, that i just can choose from .fusion and .superrepo!
It´s not possible to choose backgrounds anymore from my local media like c:\.
Is this a bug or a problem with my system?
Any Ideas or help?
p.s: With the normal Aeon Nox i can choose backgrounds from my local media, as normal!
Best regards
Timo
