(2019-02-20, 18:08)Seanj99 Wrote: [ -> ]Thankyou kindly sir, worked a treat
(2019-02-21, 03:21)VectorZ Wrote: [ -> ]Ok fair enough but I tried every step to comply and I never saw any mention that the posts had been moved elsewhere. I even tried to PM you to get a nod of approval and avoid posting on the thread but it wouldn't let me.
I'm sorry but I'm new around here and was simply trying to give Mike some feedback as requested to iron out an issue on his good work. I will try and do a clean install at the weekend.
Thank you for your guidance and sorry if I gave you a hard-on
I'm not sure if you think that I am ok with breaking
forum rules (wiki) but I am most definitely not. Everything Karellen has said is 1000% accurate. Not a typo, 1000%!
You are the only person, as of now, describing this issue and you are also choosing to use whatever you want so please understand that I will not look into anything without a "proper" "
unaltered"
debug log (wiki) so I humbly ask you to please only post again if you can provide a 100% clean log. Who knows how many hours I have spent on this... But I can tell when the log is changed. It is not that hard even if you happen to delete the colored offending bits in the log including line breaks this time but it really is not that difficult to notice. Time Stamps are by the millisecond and if you go through the log by millisecond then congrats but still not worth it cause we can tell
(2019-02-21, 04:01)Karellen Wrote: [ -> ]@VectorZ
No problems. MikeSilvo doesn't like the banned stuff either, as many of the piracy builds are using his hard work on this skin. With all those banned items you have installed, it also leads to the question of whether you have the original AeonNox:Silvo installed or a version installed by a build.
Your account is still too new for PM's, edits and a couple of other functions on the forum. Another couple of weeks and you should have all your privileges granted.
Anyway, I always ping members when I respond, so keep an eye on the New Message icon, usually in the top right corner of the screen. Click it and it will take you to the post. See image which shows 1 new ping in blue circle.
I'll leave this post for a bit to let you see it, then I will remove it as Mike doesn't like his thread cluttered up with too much off-topic talk.
1,000,000%
again... Not a typo
Only thing I disagree with is "Mike doesn't like his thread cluttered up with too much off-topic talk" however this is also infinitely accurate other than me wanting all users to read this so there is never any confusion but other than that 1,000,000,000,000,000,000,000% accurate
(2019-02-21, 04:02)AGLyons Wrote: [ -> ]There's SD, HD and 3D icons (when looking at infowall). But there doesn't seem to be a 4k icon. The space just goes blank.
Is that just me or everyone?
Can it be added?
LE-V9
Kodi18
AESilvo V6.1.8
HD/SD/3D only provide that which has been previously mentioned "Is it HD/SD/or 3D". I would need a matching image from some "awesome user"
that says 4K and "fits" with the other images for me to add.
(2019-02-21, 04:18)shedrock Wrote: [ -> ]When I press "Info" I get the plot information (left arrow) but the cast (right arrow) is just blank. Is there something I am missing?
Thanks in advance, and thank you for the hard work on this skin.
Shedrock
I hope that this is not like the past issues we have discussed cause I "think" I remember not being able to assist you then...
I hope that it is a different story now
The "right arrow" showing cast is populated by Kodi info so if the info is correct and you see cast info for that item in DialogVideoInfo.xml then I am currently unsure how to assist.
I do not and likely will not ever rely on any add-on to provide or change the Kodi info that I expect to be provided for library items added to Kodi.
That being said. You sir, Mr. Shedrock have provided both skinning help and assistance to users in the past and I will always respect the kindness which you have shown to others so if you need to speak with me privately to fix anything at all I hope to be able to provide that. Please send me a PM and if my inbox is full please post here so I can delete some "messages"
I truly hope I can help you this time and you have my thanks
