(2023-12-29, 20:05)mikeSiLVO Wrote: [ -> ] (2023-12-29, 19:33)G_streamer Wrote: [ -> ]Okay, the crash log with the Silvo skin is here: https://paste.kodi.tv/arixuhokup.kodi
The successful scrape log (no crashes) from the Estuary skin is here: https://paste.kodi.tv/ogoqigepat.kodi
You never leave the home screen using Estuary. What happens when going into the actual movie section or whatever it is you are trying to play?
Process is basically the same. I have added a movie to the Kodi library, then configured Kodi under the media/library settings to read the movie file folder of the add-on. I've tested 3 different add-ons including themoviedb-helper and the results are the same.
In the default Kodi skin I click on the Movie title under Movies and it launches the play process with no issues. Then when I switch to the new Silvo skin, I click on Movies from the menu and it displays the movie in my library. I click on it and it's an instant crash. Not even a micro second of delay. Never had any issues with Nexus and that version of your skin. It just doesn't work for the Kodi library at all. Playing direct from the add-on works perfectly as well. No issues with the metadata either, just terminates Kodi on click.
(2023-12-29, 22:40)G_streamer Wrote: [ -> ]Process is basically the same. I have added a movie to the Kodi library, then configured Kodi under the media/library settings to read the movie file folder of the add-on. I've tested 3 different add-ons including themoviedb-helper and the results are the same.
If you go into the movie library while using Estuary and play the item (
not from the home screen) and it does not crash, please post the log file so I can compare.
(2023-12-30, 04:11)G_streamer Wrote: [ -> ]Here ya go: https://paste.kodi.tv/aqiremocuv.kodi
Not sure what you're doing but you are not playing the item from the same paths.
In Aeon Nox you:
CGUIMediaWindow::GetDirectory (videodb://movies/titles/)
In Estuary you go through whatever this plugin is:
CGUIMediaWindow::GetDirectory (C:\Users\Gerald\AppData\Roaming\Kodi\userdata\addon_data\plugin.video.homelander\Movies\)
So when you click on it in Estuary you get a strm file:
CApplication::ProcessAndStartPlaylist(C:\Users\Gerald\AppData\Roaming\Kodi\userdata\addon_data\plugin.video.homelander\Movies\Guardians of the Galaxy (2014)\Guardians.of.the.Galaxy.2014.strm, 1)
In Aeon Nox you get:
CApplication::ProcessAndStartPlaylist(videodb://movies/titles/1, 1)
I guess Kodi doesn't like that so it crashes.
Doubtful this is a skin issue.
(2023-12-29, 02:56)mikeSiLVO Wrote: [ -> ] (2023-12-29, 01:24)lynxstrike Wrote: [ -> ] (2023-12-28, 23:14)kikassridec2 Wrote: [ -> ]Can't seem to find that folder??
C:\Users\YOUR_NAME_HERE\AppData\Roaming\Kodi\addons\skin.aeon.nox.silvo\16x9\SETTINGS.XML
Close, for Windows it would be:
C:\Users\YOUR_NAME_HERE\AppData\Roaming\Kodi\userdata\addon_data\skin.aeon.nox.silvo\settings.xml
For other OS's the wiki page I linked to would show what the location would be for that system.
ok so heres the settings
[mod] URL to a pastebin of the settings, please keep logs & long lists out of the forum.
https://paste.kodi.tv/dapururusu
(2023-12-30, 11:41)kikassridec2 Wrote: [ -> ]ok so heres the settings
Should be fixed on git now. If not let me know :)
I think I have resolved most issues other than the "I don't like the new OSD buttons, change is scary so my unmentionables are now brown, or I want to use my own buttons but do not want to figure out how to do so"...
If anything is still problematic using the latest from GitHub then please let me know as soon as possible otherwise, it will have to wait for the next skin update and I won't be updating to Kodi repo too often. I refuse to burden the Kodi repo skin reviewer and Aeon Nox is available for testing way before it is
PR'd to Kodi so if you do not feel like providing feedback then you will have to be patient between automatic updates.
(2023-12-31, 22:35)mikeSiLVO Wrote: [ -> ]I think I have resolved most issues other than the "I don't like the new OSD buttons, change is scary so my unmentionables are now brown, or I want to use my own buttons but do not want to figure out how to do so"...
If anything is still problematic using the latest from GitHub then please let me know as soon as possible otherwise, it will have to wait for the next skin update and I won't be updating to Kodi repo too often. I refuse to burden the Kodi repo skin reviewer and Aeon Nox is available for testing way before it is PR'd to Kodi so if you do not feel like providing feedback then you will have to be patient between automatic updates.
Happy New Year Mike! Thanks for all your work on the BEST Kodi skin there is!
I've never installed from GIT before ? I do believe there is a step by step on page 1 so will see how I get on
Hey Mike best wishes for 2024.
Do you think that it is possible to add the option of small icons in the video file section
Now i can choose between list and icons but the icons take almost the compleet screen.
https://imgbb.com/vxDGJ38
It would help me a lot.
thanks
H.
(2024-01-02, 11:36)Input1963 Wrote: [ -> ]Hey Mike best wishes for 2024.
thanks
H.
Small Icons view was removed and added as a setting to Icons view. So anywhere you see Icons view just enable the Small Icons option in
Icons: Settings.
(2024-01-02, 17:00)mikeSiLVO Wrote: [ -> ] (2024-01-02, 11:36)Input1963 Wrote: [ -> ]Hey Mike best wishes for 2024.
thanks
H.
Small Icons view was removed and added as a setting to Icons view. So anywhere you see Icons view just enable the Small Icons option in Icons: Settings.
Sorry Mike, but in the icons settings there is no option for small view.
There is only: Topbar and status indicator.
(2024-01-02, 17:17)Input1963 Wrote: [ -> ]Sorry Mike, but in the icons settings there is no option for small view.
Hmmm… Ok, will have to check when I get home.
(2023-12-21, 19:57)mikeSiLVO Wrote: [ -> ] (2023-12-21, 17:22)FoxForceFive Wrote: [ -> ]I've just had the update, & I can't find the BannerPlex view for TV shows?
Please, please tell me this is just an oversight, not a permanent change?
Check What's new in the skins add-on info. BannerPlex and Small Icons views were removed and added as settings to BannerWall and Icons views.
Ah, ok, thank you!
I've looked in settings in Bannerwall though & can't see how to switch it to to the BannerPlex style view?
Feel pretty stupid having to ask, cos there aren't that many options but I can't seem to find it.
