I just tried updated on my Krypton test install and everything went fine.
You could try deleting the skin.aeon.nox.silvo-6.0.8.zip file in your addons/packages folder then try updating again.
If it doesn't help then I will need a
debug log (wiki).
(2017-07-23, 02:12)mikeSiLVO Wrote: [ -> ]I just tried updated on my Krypton test install and everything went fine.
If it doesn't help then I will need a debug log (wiki).
Thanks for the suggestion! Just before your response came in I went and restored a backup from a week ago (I'm on LibreELEC, so it was easy for me) and after booting up after the restore, the skin updated automagically to 6.0.8 correctly!
All is well, thanks for the skin and the support!
Many thanks mikeSILVO for the help.... I have one other small question. It appears that music artist logos automatically download. This may not be an issue for some but some artists I have dont have logos.
Is there a way to stop these downloading or displaying. I I have tried to manually delete them but they reappear. If you guys could help that would be great
Is this a button no to turn off that I cannot find on the skin or is it to do with something else
Thanks in advance
Gazman2003
Sorry my fault I have doubled up my same post without realising it worked before and has been responded to by mikeSILVO.
To answer you're further question yes I would like to be able to either turn artist logos off as an option or stop then downloading automatically. I suppose is there an option for the in skin helper
Im trying to get Conditional weather background ( background for Weather menu to change regarding of the current weather and conditions). Can this be achieved on this skin? I get the forcast as widget but no luck eith background. Any advice would we appriciated. Txs
Edit: Here is how.
1. Download Image pack from add-ons
2. Enter weather and choose that pack
3. Then in Backgrounds for Weather meny the Conditional weather will show up.
Hello mikeSiLVO,
I liked this view a lot in Helix, just upgraded yesterday. Is there a chance to get it in Krypton?
(2014-12-25, 03:00)romeon Wrote: [ -> ]
Thx very much!!
(2017-07-14, 20:50)mikeSiLVO Wrote: [ -> ]The option for extra fanart is limited to 4 images due to how it works at the moment. When you cache the artwork it is added to the artwork DB as ListItem.Art(extrafanart1) - ListItem.Art(extrafanart4) and is called as such using a fade label control located here. There is support for 10 but you would have to modify script.toolbox to do so. I have forked that repository and changed the amount to 10 for an older version and you could use that commit to see how to do it with the latest version if you wanted to. Support for 106 images won't be added in the skin.
I was gonna try to tinker with this .. I think I know what I need to do with the MyVideoNav.xml you pointed me to. Just not quite sure what/where to look for in script.toolbox. Any chance a quick pointer what I would need to change to expand it from 4 to 10 like you suggested?
I checked it on my old HTPC. The above mentioned option in Helix was "enable small shift".
It would be really really great if this option could be realised in Krypton again
(2017-07-23, 06:17)gazman2003 Wrote: [ -> ]Many thanks mikeSILVO for the help.... I have one other small question. It appears that music artist logos automatically download. This may not be an issue for some but some artists I have dont have logos.
Thanks in advance
Gazman2003
There isnt a button currently. I will have to add one.
(2017-07-25, 03:09)pletopia Wrote: [ -> ]I was gonna try to tinker with this .. I think I know what I need to do with the MyVideoNav.xml you pointed me to. Just not quite sure what/where to look for in script.toolbox. Any chance a quick pointer what I would need to change to expand it from 4 to 10 like you suggested?
My reply you quoted provided you the instructions.
Click the GitHub link on the first page and click my username before the Aeon-Nox-SiLVO and look for the forked script.toolbox repository then check the last commit.
(2017-07-25, 13:47)romeon Wrote: [ -> ]I checked it on my old HTPC. The above mentioned option in Helix was "enable small shift".
So... Enable that in Krypton cause the option was never removed, it is still there
argh, you're absolutely right, sry!
(2017-06-22, 06:30)mikeSiLVO Wrote: [ -> ] (2017-06-22, 06:00)volkanogrl Wrote: [ -> ]Hi all,
I love the skin. I am just having one problem. I have set up both widgets and can access widget1 by pressing up and it allows me to scroll through the posters and choose what i want but i can't access widget2. It loads the posters but i cannot press down to scroll through them and select them. The upper widget (1) is trakt progress and the lower wider (2) is trakt watchlist. Both widgets use custom panel extended as the style, poster as the art and panel widget info is enabled.
Thank you in advance for any help
Bug. Please try latest from Git to see if everything is working as it should be.
Hi Again,
Thank you for your reply. I haven't had a chance to try to fix this yet but just wanted to ask that if i try to load the latest version from Git will i lose all of my current setup and have to set it all up again (as far as menus and submenu's and widgets etc). Thank you.
Hallo,
Thanks for the wonderful Skin.
I miss one thing: The osd display should hide automatically.
<control type="label" id="9025">
<width>auto</width>
<height>41</height>
<label>Build Version 1.5 | $INFO[System.Date,[COLOR grey], | [/COLOR]]$INFO[System.Time]</label>
<font>font13_title</font>
<textcolor>$VAR[ThemeHomeLabelColor]</textcolor>
<shadowcolor>shadow</shadowcolor>
</control>
Gah, since updating the skin to the latest version, I used to be able to add custom text here in the label field, now it is not displaying. Any ideas why? Only the date & time displays...
Many thanks
(2017-07-26, 02:41)volkanogrl Wrote: [ -> ]Hi Again,
You can use either the latest update I pushed to my repo or the download on the first page. You don't have to use git.
Updates have no effect on settings or menus.
(2017-07-26, 10:37)white-duck Wrote: [ -> ]Hallo,
I have no idea what your talking about
(2017-07-26, 13:37)Fojjidan Wrote: [ -> ]<control type="label" id="9025">
<width>auto</width>
<height>41</height>
</control>
Many thanks
There are 3 labels so add it to all of them if you don't know which one you need.
