Hey guys....,
is there a way to activate fake discart in Silvo Mod for Krypton?
I liked it so much in Isengard and for my foreign language some discarts are not available.
Sorry if it was asked earlier in the forums. and also sorry if im just being blonde, but it seems that backgrounds are not working on custom widgets?
Is that correct or am i missing something?
(2017-07-06, 19:27)flhthemi Wrote: [ -> ]Be interesting to see how the Boss is going to do that.
If you make changes to the code across several .xml files and then MikeSilvo makes changes to some of those same files, how would you suppose he could keep from overwriting your changed files when he issues an update?? YOU should make notes of what your changes are and to what files the changes were made. Then you can just edit your changes to the updated skin files. A simple copy and paste would do the trick for you. Also a look at the git for the version of the skin you use could possibly give you advanced warning of the changes that are coming....
You might also turn off automatic updates. This way you can be ready for the change.
I am not changing anything with the .xml files, only adding personalized textures (.xbt) and fonts. I've been doing copy/paste all this time and I know I can turn off automatic updates. My question is whether it is possible or not to keep those textures when updating, instead of erasing them on every update.
I guess this would be a question which concerns Kodi in general, since all updates are done in the same fashion. I guess I wrote before I thought it through.
Anyway, it would be nice to have a different post where we would all share .xbt textures besides the stock Aeon Nox ones.
Just updated to Aeon Nox Silvo (LOVE IT!!)
Hello.
Sorry for bad english. I come for germany.
I love is skin.
For movies InProgressMovies is a playlist, show which Movie is InProgress.
So i want it for streams.
Is that possible?
THX
(2017-07-12, 19:02)Frittenfred Wrote: [ -> ]Hello.
I love is skin.
Is that possible?
THX
Frittenfred,
For that to be possible, you would have to add the streams to your library, since video playlists only work for library items. Check to see if the video streaming addon you use has an option to export the streams to the Kodi library (a lot do). Then, add the folder where the streams are stored as a video source, and scan it like any other video source. This should add them to your library. After that, you can include them in any playlist you have.
Regards,
Bart
Infowall issues:
regular layout: text/pics not visible
alt. layout: text overlapping
(2017-07-12, 22:55)VelvetKevorkian Wrote: [ -> ]Infowall issues:
Literally just started looking into this 15 min ago... Will push a fix to Git in a few min.
Thanks for the info
it helped me track down the problem much faster than it would have probably taken me
(2017-07-04, 23:00)zorro75 Wrote: [ -> ]Hi, first thank you fro your work. I have a question about OSMC and Network settings menu.
Using RPi3 with OSMC and kodi 17.3 with your (awesome) skin.
But when i need to connect wireless Wifi i have to change the skin, go back to estuary, reach OSMC submenu in Systeme then i have the Network menu.
Is there any solution or any way to have this particular menu on my Silvo skin ?
Thanks a lot !
Not sure if this is accurate but a google search showed that there should be a Programs entry called My OSMC that will take you to those settings. If not you would have to ask for help from the OSMC forums.
(2017-06-27, 05:11)Dani78 Wrote: [ -> ]Hello! Thanks for the reply.
Yes it's correct. Appears in the MyFlix view.
But it's not really what I'm looking for (maybe I'm confused with another skin).
What I am looking for is that in the RightList view the DiscArt appears from behind the Case (spinning?)
Maybe it's a function that stopped working at 17.3 ...
It works if you enable the option and have used Artwork Downloader to fetch the artwork.
(2017-06-28, 11:41)FoxForceFive Wrote: [ -> ]Found the option to switch it off, I'd somehow missed it in the Video OSD section, I just saw the Netflic reference & ignored it the first time, oops!. I'd still like a more graphic based choice like I mocked up if at all possible, but I'm happy with this for now!
I like that minimalist look so I'll add an option with no plot or cast when I can.
(2017-07-02, 07:23)Edworld Wrote: [ -> ]mikesilvo,
On dialogvideoinfo the tomatoes ratings are showing .. after the rating.
I also noticed that the blurred effect doesn't work for all movies, not sure if this is a bug or just happening to me. For example, LOTR movies and extended are not showing the blur effect.
Blur effect is being wonky ATM so I will have to look into. For the tomatoes rating I haven't installed the latest betas of skin helper yet so I don't see what you see since it all stopped working for me when OMDb stopped providing that info without an api key.
(2017-07-02, 10:36)fletcherj23 Wrote: [ -> ]Does anyone happen to know where the setting is, or what file to edit to change the date and time. Doing the regular theme color changing doesn't change it. It stays white which makes it hard to see with certain backgrounds.
You would have to change the color in the xml or pick a color for the System Bars in the color picker so you can see it regardless of background.
Hey Boss...(Mike) I've been using tripanel view for movies and TV episodes for a while now. I have noticed more frequently sometimes I'll enter in to a movie list and tripanel and list view will swap back and forth on the own. Is this something you know about or something I have wrong in a setting somehow....
(2017-07-13, 15:17)flhthemi Wrote: [ -> ]Hey Boss...(Mike) I've been using tripanel view for movies and TV episodes for a while now. I have noticed more frequently sometimes I'll enter in to a movie list and tripanel and list view will swap back and forth on the own. Is this something you know about or something I have wrong in a setting somehow....
This sounds like a possible ViewModes6.db issue to me. Over time I switch views often for testing or the family likes a particular look so they switch and sometimes there are issues like remembering what view you last chose and other weirdness.
I'd start with deleting the ViewModes6.db file in
userdata (wiki)/Database folder while Kodi is off and restarting. You will then have to select your default view choices again but if your issues are related to that then all shall be right in the world once again.
Thanks! I'll give it a whirl see what blows...
Edit:
It worked!
(2017-04-05, 20:35)heula Wrote: [ -> ] (2017-04-05, 19:12)mikeSiLVO Wrote: [ -> ] (2017-04-05, 09:21)heula Wrote: [ -> ]I just now notice that the background rotation (backdrops) for series and movies are not rotating in the series, episodes and movies level. At the start screen the backgrounds are rotating every 5 seconds per item.
Is this by design or not?
Backdrops in the series and movies folders are named backdrop, backdrop1, backdrop2 etc.
Kodi log.
You have to enable Extra-fanart and cache it for Movies, TV Shows or both in Sidemenu > Background.
Fanart and extra fanart are and were enabled for all series. Even when I set fallback it does nothing. It keeps showing the first backdrop only.
Using Emby addon, perhaps this has something to do with it?
I do not see the options cache movie and series extrafanart.
First I'd like to say, great job with the skin. I'm an old user of Aeon and just switched to this one. Seems its got everything I like but can't seem to figure out Extra-fanart to be exactly right. I was able to get my images "cached". This enabled them to work in the root of the TV Library. Then I came across two issues.
First, its only caching 4 images, and only those 4 images cycle for me. Some of my shows have LOTS of images. Smallville for example has 106.
Second, even though its enabled in the season level and the episode level of the library, the images are not cycling there.
In past versions of Aeon neither of these two things were issues so I'm hoping this won't be an issue. I was most recently using Aeon Madnox and only the 2nd thing was an issue so thats why I switched to Aeon Nox: Silvo hoping to fix these things and finally have perfect setup again.
I'm having some issues with Auto-completion working does it not support it?
