Decided to take a week off from the forums with the possibility of me not being available as much as I was... Starting to feel a little burnt out and I need to start spending more time with my family... That being said lets see if I can get to all of these posts...
(2015-11-04, 00:05)TheBigRoberto Wrote: [ -> ]Here Is the debug Thanks
You're log is full of
banned add-ons (wiki) so check the
troubleshooting (wiki) and try a new install with just the skin and its dependencies since the problem seems to be isolated to your setup.
(2015-11-04, 01:30)Pienoet Wrote: [ -> ]Hi Mike,
The option for choosing my own weatherfanart folder on the side menu is gone and the weather based condition on the homescreen isn't showing the weatherfanarts anymore.
Did something changed in jarvis or your skin?
i have the latest git installed here is a debug
You have to pick a weather fanart resource image... Hit background in the side menu of the weather section and select get more then choose a weather fanart image addon.
(2015-11-04, 22:53)flhthemi Wrote: [ -> ]Would you consider making the scroll bars in lists and such a bit wider? It's very hard to keep a mouse lined up on them being so very narrow. I like this skin very much and would use it on all my devices but some are used with a mouse and no keyboard and some are tablets and that narrow little scroll bar is tuff to keep a finger on. Yup, I know I can drag the list but scroll bar is way faster.
Thanks for your hard work on this skin it just keeps getting better!
Sorry that would take a complete redesign of some things so it is very unlikely to happen.
(2015-11-04, 23:31)Xemaniac Wrote: [ -> ]I've done that already, that's why I'm asking. I just get the generic Skin font as the logo, not for the show.
How do I get it on music then?
Logo view is only for Movies and TV Shows.
(2015-11-06, 18:03)andrezpt Wrote: [ -> ]i have installed from the repository, if i try to install via ZIP i download from the github it stops at 4% i have to overwrite the paste in the addons?
Read the FAQ on the first page 2nd post.
(2015-11-06, 22:34)Solo0815 Wrote: [ -> ]just wait, it has to install 1000s of small files. Because of that, I asked to put all the media in a separate package:
http://forum.kodi.tv/showthread.php?tid=...pid2142849
Then you can have this packages:
- MPAA black/white
- MPAA- coloured
- watched-german
-watched-english
and so on ...
In the skin you could then set, which package to use ...
There will only be "packs" for larger things so not everything will be available as a resource addon.
(2015-11-07, 23:40)moravec Wrote: [ -> ]I just noticed that in Video Info the movie poster is low quality and pixelised... But the folder.jpg file in the movies folder is high quality. But it seems to be the same file. Can I set somewhere the quality Kodi should use?
There is an
advancedsettings (wiki) I believe.
(2015-11-08, 00:06)moravec Wrote: [ -> ]Mike why not swap CinemaVision button with ChooseArt and not with Trailer button? I actually use Trailer more than ChooseArt...
There is already an option to swap trailer for choose art if CinemaVision replaces it.
(2015-11-08, 15:56)flhthemi Wrote: [ -> ] (2015-11-08, 08:03)sxmdim Wrote: [ -> ]Mike , i don't see any player controls when i play music. I use the vertical menu , the song wil start but only thing working is clicking the "x" on the keyboard to stop playing
I noticed this too. But I found that if you go back to Home menu and then open your Movies menu the side blade has the option to go full screen!
Seems like a Jarvis bug. Are you guys using Jarvis?
(2015-11-08, 16:23)snyft Wrote: [ -> ]Using latest Skin from git and kodi alpha 4 all i get is a black main screen. context menu works.
I'm also using latest skin shortcuts.
Any idea?
If you are talking about the menu being reset and your backgrounds and menu items have returned to the skins defaults then that is normal and cannot be helped. If you are experiencing an issue where you cannot alter the main menu then with Kodi not running try deleting the script.skinshortcuts folder in your addon_data directory and deleting the script-skinshortcuts-includes.xml file in the skins 1080i folder and restarting Kodi.
(2015-11-08, 20:21)Crossfader Wrote: [ -> ]Hi, first i want to say i love your Mod :-)
I have a problem to show Extra info in Series, the Episode Titel and the Series Name are overlapped.
I use your Repo and newest Kodibuntu.
Should already be fixed on Git but you will need to re-set up your main menu. You will have to do it eventually so why not do it now
(2015-11-08, 23:55)pathartl Wrote: [ -> ]Been using this mod for 10 months or so now. Finally Aeon Nox with logos
Updated to the version from your repo, but TV show information no longer works. The context menu will just close and the input is stuck. Hitting escape/back "closes" the invisible menu. I tried to remedy this by downloading the build off GitHub for Isengard, but none of my skin settings carried over and I could not enable/disable main menu items.
The main menu has been redone using script.skinshortcuts. You will have to re-set up your main menu when the update is posted or pushed to the repo so you may want to just get it over with by installing the latest skin from GitHub.
(2015-11-09, 08:32)AL8782 Wrote: [ -> ]Can movies or tv shows be played for home screen widgets or are they just for information?
Thank You
Library widgets play the item, informational widgets show info (ie extendedinfo).
(2015-11-09, 14:26)wilmans2m Wrote: [ -> ]@mikesilvo164
hi mike,
well i installed last github version this morning and i must face to a weird problem: I have problem with my playlist
here it is :
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<smartplaylist type="tvshows">
<name>TV</name>
<match>all</match>
<rule field="path" operator="is">
<value>nfs://192.168.0.92/volume1/SeriesTV/</value>
</rule>
<order direction="ascending">sorttitle</order>
</smartplaylist>
As you see, i use "path" in my smartplaylist. But does not work anymore even if i use "contains" instead of "is". Same problem is i use smb instead of nfs.
Do not understand why and hope you will be able to fix it.
EDIT : must be tired. Works in fact. But got problems using same style playlist as widget (with path in it).
Sound like a playlist or possible skinshortcuts problem, recommend you ask in the skinshorcuts thread after installing the latest script version from git.
(2015-11-09, 17:00)emiralles Wrote: [ -> ]Hi Mike,
Your new version in github has a problem with the rss position,still. I had solved this problem and other things but I think that this corrections aren't interesting for you.
Please, correct by yourself this problem, "rss up" it's in the down, "rss down" it's in the middle. And can you consider change the rss fonts, it's very small for my tired eyes.
Thanks for your time.
Would have been fixed sooner but you never described the issue in enough detail for me to replicate and sending me files will never be added since I need to review it and combing through code changes in a diff viewer is not where I will choose to spend my time. That is what Pull Requests are for.
(2015-11-10, 06:59)maverick1960 Wrote: [ -> ]I have been searching for an answer but no luck so far.
Once a movie view has been set and I toggle info (before playback of the movie) I can see detailed info and cast. While I can see names of the actors I cannot see their photos unless I click on their name which is when I can see their complete details. Is it meant to be like this by default or am I missing the script.skin.info.service
One other irritant is that when the extended info script comes into play it saves all the movies I want to watch later (while viewing the other movies of the actor) in the script itself which I then need to view by opening the script whereas it would be great if could be visible on the main menu in my movie section, say like a widget.
Thank you for your time and attention.
Pictures should load quickly and is handled by your scraper or media manager if you use one.
If I get what your asking... there are a lot of widget available through extendedinfo but they all come from an api so if you want additional widget choices someone would need to check if watch later returns anything useful like artwork and if available then request it in the extendedinfo thread.
