(2016-05-02, 19:02)chris19123 Wrote: [ -> ]Hi Bob
I have seen your post but could you help further as per Ryan issue I am having the same problem I have edited the script in skin.aeon.nox.silvo.properties file from
['mainmenu', 'colorblack-movies-color', 'background', u'C:\\Users\\chris\\AppData\\Roaming\\Kodi\\userdata\\Backgrounds\\Movies\\'],
to
['mainmenu', 'colorblack-movies-color', 'background', u'special:\\home\\Kodi\\userdata\\Backgrounds\\Movies\\'],
But as per Ryan it takes the backgrounds out. Checked the file location which is correct so can only think my script edits are wrong.
thanks
Thanks for quoting my previous reply as that saved me some time - pulled out the relevant bit for you, and added some emphasis
(2016-03-08, 18:24)BobCratchett Wrote: [ -> ]Please backup the file first as the file isn't designed to be manually edited and, if you get it wrong, it can lead to backgrounds disappearing or even the script being unable to build the menu and the best support I'll be able to offer you is to restore your backup or delete the file.
And actually, the only method that I advocate these days is detailed here: Skin Shortcuts FAQ:
Copying menu to another system. It uses the Skin Helper script but, I understand, is designed to take care of moving backgrounds and whatnot along with the menu items.
Since the last Kryton update from Git, I've lost all of my Movie Cases on the main screen, the cases still shows fine in the list of movies.
I'm using Live Background Cases - Recent Movies.
Why do no rss feeds show up?
(2016-05-02, 22:15)BrandonCosmic Wrote: [ -> ]I need help setting up the default_bg.jpg. what xml must be edited to replace that dark black background pic. The default_settings.jpg sets up easily. The default_bg.jpg is the stubborn one. Can anyone point me in the right direction?
Wouldn't just editing the default_bg.jpg to your liking work? No code chinging needed if you do that. Or get a jpg you like and name the same.
(2016-05-02, 06:04)mikesilvo164 Wrote: [ -> ]Pushed some language sync updates. If anybody willing can install the latest jarvis branch from GitHub, look for any missing text, and report back... I'd appreciate it
Hello Mike,
I just installed the latest Jarvis-widget-dev branch and noticed that the Spanish languages strings.po are way behind the US English one. Would you like me to update the Spanish translations as per the latest Jarvis widgets-dev English one? Please let me know. Thanks.
Regards,
Bart
Hi Mike,
Is it possible to make the Live TV media flags also colored?
How do you edit picture in bottom left corner on aeon nox silvo skin? I'm using a build and would like to return this pic to default picture as above . Thanks
Sent from my A0001
No help for builds here, 'build' means only one thing, banned addons!
Fair enough, it's just a build with 1 sports addon.
Just wanted to return pic to skin creator's pic.
Thanks anyway.
(2016-05-02, 21:23)Magoo32 Wrote: [ -> ]Since the last Kryton update from Git, I've lost all of my Movie Cases on the main screen, the cases still shows fine in the list of movies.
Works fine here. Did you activate the "Enable cases for live backgrounds" option in Skin setting > General?
(2016-05-02, 21:35)aaddaamm1111 Wrote: [ -> ]Why do no rss feeds show up?
Not sure... Any idea why my Dog is pissing on the floor all the time?
I think he's mad at me
(2016-05-03, 15:57)BrandonCosmic Wrote: [ -> ] (2016-05-03, 01:30)flhthemi Wrote: [ -> ] (2016-05-02, 22:15)BrandonCosmic Wrote: [ -> ]I need help setting up the default_bg.jpg. what xml must be edited to replace that dark black background pic. The default_settings.jpg sets up easily. The default_bg.jpg is the stubborn one. Can anyone point me in the right direction?
I wish it was that simple. Thats how i did it with the regular aeon nox skin. Its more complicated with the silvo mod but i just figured it out last night.
I don't think its complicated, just pick the default image in Skin setting > General > Set default background
(2016-05-03, 18:13)bsoriano Wrote: [ -> ]Hello Mike,
Regards,
Bart
Not sure how best to handle this cause anything added may be overwritten. Can you add them on Transifex? I have no idea how to do that though
(2016-05-03, 20:42)Pienoet Wrote: [ -> ]Hi Mike,
I don't have any colored images to use. The ones for the library are not the same so someone would have to make colored versions that look similar to the current ones.
(2016-05-03, 22:38)Brock92 Wrote: [ -> ]Fair enough, it's just a build with 1 sports addon.
Thanks anyway.
That pic is from a modified version of the Helix skin and that version is no longer supported or maintained. I also cannot tell you how to remove something I didn't add.
If you want to use thist skin then just download the latest Jarvis version from Git or the first page and stop using "builds".
(2016-05-03, 23:32)REralte Wrote: [ -> ]Im missing the inf for my movies set any idea how display it
Its supose to show where the red circle is.
Thank in advanced
Most likely missing script.skin.info.service. Check the add-on status section in skin settings. If it is red and you have my repo installed it will install it for when you click on it. Otherwise it will need to be manually installed.
(2016-05-03, 23:41)mikesilvo164 Wrote: [ -> ] (2016-05-03, 18:13)bsoriano Wrote: [ -> ]Hello Mike,
Regards,
Bart
Can you please provide me the link to the project in Transifex? I think I can figure out how to contribute to the Spanish translation there. Thanks.
Regards,
Bart
