I have poster.jpg and poster1.jpg in my title folder.
Some views like 'Right list' rotate the two posters. In the 'Info' window both posters rotate. Other views like 'MyFlix' (what I prefer) do not display poster1.jpg at all.
I also have poster.jpg and poster1.jpg in my Movies- Sets Art folder for a set.
Some views like 'List' rotate the two posters. In the 'Info' window both posters rotate. Other views like 'MyFlix' (what I prefer) do not display poster1.jpg at all.
Bringing this to @
mikeSiLVO attention hoping you might know how to enable poster1.jpg, poster2.jpg, poster3.jpg, etc. for the MyFlix view.
(2023-03-03, 15:27)ashlar Wrote: [ -> ] (2023-03-02, 18:35)brazen1 Wrote: [ -> ] (2023-03-02, 17:46)ashlar Wrote: [ -> ]I get Kodi crashing every time the "cursor" goes over a specific TV Show (11.22.63) in my Big List view.
Log: https://paste.kodi.tv/acawuzoriy.kodi
Zip with stacktrace and crashlog: https://easyupload.io/tgzp2c
Is that TV show in a TV Show source or a Movie source? Strange that it crashes only when that title is focused. Not sure if any of this anything to do with it:
'?info=getbydbid&dbid=4&type=movie'
Get by DBID: No result found: invalid literal for int() with base 10:
https://www.learndatasci.com/solutions/p...t-base-10/
Removing that TV show and then scanning it back solved the issue.
Oh good. Glad you got it solved.
(2023-02-20, 18:23)brazen1 Wrote: [ -> ] (2023-02-20, 17:49)hostile17 Wrote: [ -> ]I cannot get any ratings to show on my Silvo.
Obtain an API key from OMDb. Activate the key using the link emailed to you. Change your scraper to Universal Movie Scraper using edit source. In the settings menu for the scraper in the same edit source window, adjust the settings for the rating scrapes you desire. Add your OMDb key there also. Be sure to obtain movie name from tmdb and not imdb. Also, do a little research for EVERY UMS setting before saving your adjustments even if you think you know what they will or will not do. I highly suggest you copy your entire appdata/roaming/kodi folder before doing anything so if you make a mistake you can start over.
After saving the adjustments for UMS, you will be asked if you want to refresh the entire library. That's up to you. If you don't, you have the option of refreshing every title one by one using the info window for each title. That's what I opted for choosing NO for every refresh question. As soon as the refresh completes, the rating icons appear. Hope this gives you some insight.
I am with hostile17 on this one. Cannot get ratings to appear. Have tried switching to UMS and refreshing library - nothing changed.
In theory this should be easy to set up if Embuary Info is installed. I suspect I will need to do some digging through the xmls to find a solution - although I do wonder whether having multiple rating providers for every film (for example that you are browsing in a widget pointing to tmdb helper recommended movies) might be resource intensive
(2023-03-04, 01:21)justin150 Wrote: [ -> ] (2023-02-20, 18:23)brazen1 Wrote: [ -> ] (2023-02-20, 17:49)hostile17 Wrote: [ -> ]I cannot get any ratings to show on my Silvo.
I have Embuary Info and Embuary Helper installed with the latest GitHub of this skin and Kodi v21. Doubt any of that matters since seeing others implement it with screenshots from long ago. (in this thread someplace)
You don't just switch to UMS and refresh. Did you read my details?
Are you using an official version of Kodi?
It's not resource intensive for my W11 desktop HTPC. My MB and CPU are circa 2010 with 12GB RAM because I still prefer it vs anything newer.
(2023-03-04, 02:57)brazen1 Wrote: [ -> ] (2023-03-04, 01:21)justin150 Wrote: [ -> ] (2023-02-20, 18:23)brazen1 Wrote: [ -> ]Obtain an API key from OMDb. Activate the key using the link emailed to you. Change your scraper to Universal Movie Scraper using edit source. In the settings menu for the scraper in the same edit source window, adjust the settings for the rating scrapes you desire. Add your OMDb key there also. Be sure to obtain movie name from tmdb and not imdb. Also, do a little research for EVERY UMS setting before saving your adjustments even if you think you know what they will or will not do. I highly suggest you copy your entire appdata/roaming/kodi folder before doing anything so if you make a mistake you can start over.
Of course I use the official version of Kodi, downloaded direct from the Kodi wedsite. I also use the version of Silvio skin from the Kodi website. I also followed what you said.
And it still does not produce multiple ratings. I may have done something wrong, but I tried the same approach using Tajo skin and I could get 2 ratings displayed. That implies it is the skin not me that is failing.
As for resource intensive, on a PC or laptop I agree not a problem, but what about on a firestick or tablet?
(2023-03-05, 16:37)justin150 Wrote: [ -> ]That implies it is the skin not me that is failing.
Except it isn't failing using this skin.
https://forum.kodi.tv/showthread.php?tid...pid3138775
(2023-03-05, 16:37)justin150 Wrote: [ -> ]I also use the version of Silvio skin from the Kodi website.
I'm using this version but it probably doesn't matter. Not sure.
(2023-03-04, 02:57)brazen1 Wrote: [ -> ]installed with the latest GitHub of this skin
(2023-03-05, 16:37)justin150 Wrote: [ -> ]but what about on a firestick or tablet?
Sorry, I don't use either of them.
(2023-02-25, 19:58)brazen1 Wrote: [ -> ]FYI. I understand Kodi v21 is only under development but I thought feedback might be appropriate.
KodiSetup-20230222-4f7194f5-master-x64.exe 76.9 MiB 2023-Feb-23 03:21
and
KodiSetup-20230224-b58fd2e8-master-x64.exe 76.9 MiB 2023-Feb-25 04:33
break Aeon Nox Silvo library posters. Estuary posters are ok though. There is no problem after reverting to any earlier Kodi 21 builds. I only tested the MyFlix view and I'm using the latest master branch as of 02-25-2023. I will remain using the last Kodi v21 build before the problem was introduced - KodiSetup-20230221-0d978b56-master-x64.exe76.9 MiB2023-Feb-21 03:45. If/when I notice any GitHub update, I'll test it again. Thanks for any early attention @mikeSiLVO might provide.
Yes, posters are now back to working as of today using KodiSetup-20230307-e37f1e40-master-x64.exe77.0 MiB2023-Mar-07 03:21
I'm getting ready to upgrade from Kodi 19.4 to 20.1 and have a quick question. Does the Aeon Nox Silvo Nexus version still have the logo view for movies and tv shows?
Simple question but probably a complicated answer!
I have downloaded and am using script.info.service specifically to ensure the skin displays the information I need on Movie contents.
In widgets I have amended the xmls to show slightly different info in widget info from standard Silvio. Currently if I ask it to display release dates for the movies in the set (using $INFO[Window(Home).Property(SkinInfo.Set.Movies.Years]) what I get is Movie 1 Year/Movie 2 Year/etc. What I want to be displayed is release year of first movie in set and last movie in the set only. What is the coding to achieve that
