(2022-06-23, 16:05)flhthemi Wrote: [ -> ] (2022-06-21, 15:10)lynxstrike Wrote: [ -> ]Nop... PC, W11 Pro 22H2
I made a fresh new skin install (Aeon Madnox, not SILVO) and the menus and submenus work fine, without incident. The thing is, all color customization is lost (colorpicker addon is broken in Nexus).
I have just run into the same issue. Did you manage to resolve this? I'm using this skin (Silvo)
Use "script.skin.helper.colorpicker"
from here:
https://github.com/kodi-community-addons...-2.0.1.zip
This is up to date and also works on Nexus.
(2022-06-22, 20:05)Karellen Wrote: [ -> ] (2022-04-17, 12:15)nordicguy Wrote: [ -> ]1- animated posters for movies?
Not automatically. You could replace your standard poster with an animated poster.
The animation won't work across networks. The image needs to be saved locally
(2022-04-17, 12:15)nordicguy Wrote: [ -> ]2- playing the movie theme.mp3 that exists to the movie folder?
You will need to install the TV Tunes addon
(2022-04-17, 12:15)nordicguy Wrote: [ -> ]3- red carpet add on available in kodi repo?
Not that I am aware of.
1. it worked as you mentioned but i gave up on it as it is lots of work to change one by one all the animated posters
2. i cannot find that add on in the kodi repo, where do i install it from? the other skin aeon tajo plays the theme.mp3 without this addon so is this for this aeon nox silvo skin?
3. i do not understand your answer. you mean that you are not aware of if aeon nox silvo supports red carpet or what do you mean?
(2022-06-23, 18:04)nordicguy Wrote: [ -> ]2. i cannot find that add on in the kodi repo, where do i install it from? the other skin aeon tajo plays the theme.mp3 without this addon so is this for this aeon nox silvo skin?
https://forum.kodi.tv/showthread.php?tid=347428
Aeon Tajo uses a different method to play the tunes.
(2022-06-23, 18:04)nordicguy Wrote: [ -> ]3. i do not understand your answer. you mean that you are not aware of if aeon nox silvo supports red carpet or what do you mean?
Aeon Nox does not support the red carpet addon. No provision has been made in the skin to display the images from the resource addon.
(2022-06-23, 20:44)Karellen Wrote: [ -> ] (2022-06-23, 18:04)nordicguy Wrote: [ -> ]2. i cannot find that add on in the kodi repo, where do i install it from? the other skin aeon tajo plays the theme.mp3 without this addon so is this for this aeon nox silvo skin?
thank you so much. i installed tv tunes and themes works fine now
by the way, I managed to edit the skin settings, variables, and several other xml files to get the animated posters working automatically including adding a button in the skin itself to enable it. it is adhock solution really and I am surprised it worked at all.
of course I have to be careful and make backup since the skin can be updated in the future.
I might as well be encouraged to see how the red carpet work in the other skin and do something about it in this skin.
again thanks for this wonderful skin. i see it became my favourite so quickly
(2022-06-23, 21:13)nordicguy Wrote: [ -> ]by the way, I managed to edit the skin settings, variables, and several other xml files to get the animated posters working automatically including adding a button in the skin itself to enable it. it is adhock solution really and I am surprised it worked at all.
That is great. Maybe you could submit a PR to include the setting in the skin. Prefer animated poster, but fall back to plain poster if it does not exist.
The author of the skin is not as active as he used to be....
https://github.com/mikesilvo164/Aeon-Nox-SiLVO
This is how aeon tajo does it...
https://forum.kodi.tv/showthread.php?tid=330832
(2022-06-23, 21:40)Karellen Wrote: [ -> ] (2022-06-23, 21:13)nordicguy Wrote: [ -> ]by the way, I managed to edit the skin settings, variables, and several other xml files to get the animated posters working automatically including adding a button in the skin itself to enable it. it is adhock solution really and I am surprised it worked at all.
The author of the skin is not as active as he used to be.... https://github.com/mikesilvo164/Aeon-Nox-SiLVO
This is how aeon tajo does it... https://forum.kodi.tv/showthread.php?tid=330832
hey man yes sure. although all i did was copy / paste actually from aeon tajo to address the concern of fall back because not all my movies have animated poster.
pasted that in aeon silvo and changed very little of the code to match what is done there.. while fingers crossed to make it work
then made a radio button i added it in the SilVO Extra section. again copy/ paste from a similar radio button in aeon nox silvo. renamed it, gave it id, gave it message and message id then add that in all english language files. have not touched any other languages. so i will dig deep to know how to submit that PR in an understandable way
i'd post some screenshots but i do not know how to do that in the forum
(2022-06-23, 17:12)Fuchs2468 Wrote: [ -> ] (2022-06-23, 16:05)flhthemi Wrote: [ -> ] (2022-06-21, 15:10)lynxstrike Wrote: [ -> ]Nop... PC, W11 Pro 22H2
from here: https://github.com/kodi-community-addons...-2.0.1.zip
Thanks a LOT! It worked like a charm!
BTW - I sure hope Mike's OK...
Is there a way to show the movie info in the Panel Widget Info for the Favorites option?
I have two widgets on my Movies section, top one is Random movies and the bottom one is my Favorites. When I select a movie in the Random widget I get the movie info but when I select a Favorite movie there is no info, just the name. I tried putting Favorites on the top and Random on the bottom but it didn't work either.
EDIT 6/29/22
Turns out it's the moviedb helper addon. Soon as I disabled it the problem stopped.
It also seems to have stopped my view from being changed as well.
Now back to the original post....
EOE (End of Edit)
Here's a little thing I've been trying to figure out. When I go to a list of TV shows in Tri panel view the info changes from genre to status info in less than a second. (see Video) Am I missing some setting that would stop this. I notice it doesn't happen on my Android tablet but it does in all my Windows installs.
The video
HERE
These are screen caps from the video I have provided because the change from one to the other is so fast. It also MIGHT be the cause of my view (Tri Panel) abruptly changing back to list view.
Genre Shows
Genre GONE!
having an issue getting the video options OSD up when pressing pause on the keypad or keyboard -
when paused i am used to an OSD to come up with video playback options that give options to select the amount of zoom, change the sound offset, change the volume amplification etc etc
but when using the Aeon Nox SiLVIO skin - when i press pause i get the video progress bar - but not the menu of symbols underneath that i am used to seeing - ie no cog icon, no options to adjust zoom
i want to get this menu
https://i.ibb.co/4V8n6gB/Screenshot-20210616-004454.png
but i just get a progress bar like this
https://i.ibb.co/824DZwq/Screenshot-20210616-005159.png
for info i am using LE, Kodi 19.5 and the guys at LE confirm its a skin issue rather than a LE issue
(2022-07-02, 18:04)garz Wrote: [ -> ]having an issue getting the video options OSD up when pressing pause on the keypad or keyboard -
Imo, when you press pause, video playback should simply pause. There is a setting (Prefer clean pause) to force this to happen if for some reason unwanted things appear on a paused screen although I find it unnecessary. If you want things like a progress bar to appear or eye candy such as a logo, there are settings to automatically add them to a paused screen. There is no setting to overlay player controls automatically when pause is pressed I know of. If you want player controls to appear, press M or whatever M is mapped to on your remote control after you press pause. Then you can scroll to the desired category setting you want to fiddle with such as zoom or audio offset you mentioned. Fwiw, many keyboard keys can be mapped to a decent remote control without navigating into a specific menu to operate them. They can be adjusted on-the-fly and show up at the top of the screen as you adjust it/them. Audio offset for example - press A.
https://github.com/xbmc/xbmc/blob/master...d.xml#L159
https://kodi.wiki/view/Keyboard_controls
https://forum.kodi.tv/showthread.php?tid=203931
