(2015-05-14, 14:18)grimmace92 Wrote: [ -> ] (2015-05-14, 07:15)grimmace92 Wrote: [ -> ]Hi. I'm new to Kodi and bought an android device. I can't seem to install this mod. I've tried both zips and they both fail. The one from git says dependencies not met and the other zip says it doesn't have the correct structure. I was able to install the extended info script with no problem via usb. Can someone point me in the right direction? Thanks!
i downloaded it right from the first post in this thread on a windows 8.1 machine and then copied it to a thumb drive to put it on the android machine. here is what is inside the zip called skin.aeon.nod.silvio-5.6.0-1.8.2
skin.aeon.nox.silvio folder
inside that folder is this
1080p
background
colors
extras
fonts
language
media
shortcuts
skinextras
sounds
themes
thanks for the help[/align]
One thing I noticed with my Fire TV (android based) is that sometimes (not always) when installing a zip from a network share, like nfs or samba, I get dependency errors. Copying the zip to a local folder on my fire tv, then installing works. If you're installing from a network share, try it from a local folder.
Hi Mike
Love your mod! Added one or two things that tipped the scales for me into sticking with Aeon Nox
Very minor thing I noticed, and not sure if this is a bug or deliberate, but when viewing Seasons, Sets and Addons in Shift view, FloorLabelVar and FloorLabelSubVar are missing. I assume this is not intentional as it would seem odd to remove this just for these content types.
Easily fixed by editing MyVideoNav.xml around line 250, but just thought I would mention it.
EDIT: Just sent a pull request. Still a github noob so hope I did it right!
(2015-05-14, 11:21)mikesilvo164 Wrote: [ -> ]....
I really love your mod
Question: Is it possible to change the viewmode for all movie sets one time?
Movie>>MovieSets
(2015-05-14, 05:49)mikesilvo164 Wrote: [ -> ] (2015-05-14, 05:40)monisriz Wrote: [ -> ]Yes I can confirm that there is some cropping (top & left) with the posters in BigFan view mode. When you click on the movie to get the bigger poster image the issue still exists. I checked the poster image outside of kodi and it seems to be a full sized image.
Any idea what's causing this if it's an isolated issue only at my end?
What screen resolution? Kodi and skin version? Can you post a screenshot so I can try to replicate the problem?
Screen Res: 1920x1080
Kodi Ver: Helix 14.2
Skin Ver: 5.6.0-1.8.2
Screenshots below (actual poster images are 1000 x 1500).
Image is cropped from the top in BigFan view mode.
However, it looks better when clicked once to get the full size poster.
Another example:
For some other titles there is a bit of cropping on the left side as well. But those images are not 1000 x 1500 and I would need to resize them first to see if the issue persists.
I have no idea about skin related issues at all but one thing I read about today has something to do with "Aspect Ratio" settings (
Aspect_Ratio (wiki)). Could any of the 4 values in this link be causing it?
Thanks a ton for great work!
(2015-05-14, 12:52)wilmans2m Wrote: [ -> ]Hi Mike. Glad to see you here again
Do you manage to create movie set box i asked you a few weeks ago ? (page 68)
=> http://forum.kodi.tv/showthread.php?tid=...pid1947055
http://forum.kodi.tv/showthread.php?tid=...pid2002452
(2015-05-14, 14:18)grimmace92 Wrote: [ -> ]Hi Mike,
I downloaded it right from the first post in this thread on a windows 8.1 machine and then copied it to a thumb drive to put it on the android machine. Here is what is inside the zip called skin.aeon.nod.silvio-5.6.0-1.8.2
1080p
background
colors
extras
fonts
language
media
shortcuts
skinextras
sounds
themes
thanks for the help
Not sure why you are getting that error... I just reinstalled the skin myself and received no error message on win 7. You can always just extract the contents and place the skin.aeon.nox.silvo folder to the addon folder located in the same parent directory as your
userdata (wiki) folder.
(2015-05-14, 14:42)eskay993 Wrote: [ -> ]Hi Mike
Merged your pull request.
(2015-05-14, 16:02)marhutchy Wrote: [ -> ]I really love your mod
Movie>>MovieSets
Not that I know of
(2015-05-14, 18:28)monisriz Wrote: [ -> ]Screen Res: 1920x1080
Another example:
I have no idea about skin related issues at all but one thing I read about today has something to do with "Aspect Ratio" settings (Aspect_Ratio (wiki)). Could any of the 4 values in this link be causing it?
I removed the aspect ratio tag so it defaults to stretch. It is on
Git if you want to try it.
Hi My question might be naive but any one knows how to get 'CJK' fonts in aeon nox silvo ??
any help is appreciated, as im unable to see japanes/korean titles
thanks,
(2015-05-15, 08:16)prakashparvath Wrote: [ -> ]Hi My question might be naive but any one knows how to get 'CJK' fonts in aeon nox silvo ??
thanks,
Does switching to Arial font in the appearance settings help? I am not sure about this but I recall hearing that Arial worked with the characters used in Japanese and Korean languages.
mikeSiLVO
Awesome ! You've done a great job. I do not see this post
Thanks for the reply.
Will test it out & leave feedback.
Thanks again.
Once again : Glad to see you here again (it means you're fine now i hope).
(2015-05-15, 06:51)mikesilvo164 Wrote: [ -> ] (2015-05-14, 12:52)wilmans2m Wrote: [ -> ]Hi Mike. Glad to see you here again
1080p
background
colors
extras
fonts
language
media
shortcuts
skinextras
sounds
themes
thanks for the help
Not sure why you are getting that error... I just reinstalled the skin myself and received no error message on win 7. You can always just extract the contents and place the skin.aeon.nox.silvo folder to the addon folder located in the same parent directory as your userdata (wiki) folder.
Movie>>MovieSets
Not that I know of
Another example:
I removed the aspect ratio tag so it defaults to stretch. It is on Git if you want to try it.
Thanks! Will get it tomorrow and test it.
Also, is there any ideal poster size to use with your skin/mod?
(2015-05-15, 08:40)wilmans2m Wrote: [ -> ]@mikeSiLVO
Thanks again.
Still working on it so there are bugs I still need to iron out and my logic brain has been less than cooperative as of late
(2015-05-15, 08:47)monisriz Wrote: [ -> ]Thanks! Will get it tomorrow and test it.
Shouldn't need to be that exact as long as it is close to 1.5 times the width equals the height and it should work. If it does not I need to try something else to make it work. If it is not close to that ratio the image may look squished.
(2015-05-15, 08:47)monisriz Wrote: [ -> ] (2015-05-15, 06:51)mikesilvo164 Wrote: [ -> ] (2015-05-14, 12:52)wilmans2m Wrote: [ -> ]Hi Mike. Glad to see you here again
1080p
background
colors
extras
fonts
language
media
shortcuts
skinextras
sounds
themes
thanks for the help
Movie>>MovieSets
Not that I know of
Another example:
Thanks Mike. I don't know how but my original download was not complete. I downloaded again and it installed no problem. Skin is awesome. Really nice work. Is it possible to add something like the fake disc art recently available in shednox skin? I have some movies that can't find the disc art. Thanks!
I think we should let Mike resolve the bugs before adding new features. But this is an interesting one.
Hi guys ,
I am using Aeon Nox with Silvo skin and I am generally very happy with this great skin ( Thanks Mike again for creating it ) .
Anyway , I am facing a few issues and I would like to ask you for your assistance .
For example , when I am watching Live TV and I am pressing on the "info" or "I" on the keyboard , I'm getting the screen below .
Also , on the bottom of the picture I really don't understand what are the letters on the left corner and what is the meaning of the letters (ABCD) on the right corner ...I'm getting the same info for every live channel . Do I need this info ? If not , how could it be removed from the "Info" page ?
And a second question : There is any way to improve the informations I am getting on this screen ( different icons , colorful icons instead of black and white etc ...) ?
Thanks in advance !
