(2019-03-03, 19:50)Seanj99 Wrote: [ -> ]
Not sure why my layout differs to yours?
I could be wrong, but I think this option is hardware dependent. For example, the brightness & contrast adjustments were not available on my Raspberry Pi with Kodi 17.6 and Aeon Nox 5: SiLVO, but were available on my Intel based HTPC's (Windows & LibreELEC).
I'm not using the Pi anymore so I'm not sure if the situation is the same with Kodi 18.x, but it probably is. It would be interesting to see if the brightness / contrast controls were available in Estuary but not in Aeon though...
(2019-03-03, 19:50)Seanj99 Wrote: [ -> ]Not sure why my layout differs to yours?
Maybe this
https://kodi.wiki/view/Android_FAQ#Missi...22_options
It says v16 of Kodi so it may be tied to Hardware Acceleration but I have zero experience using android so you can ask in the Android section.
Also @
whysoserious could be correct in it not being available for certain HW configs.
Yes it is hardware acceleratIon, when mediacodec (surface) is disabled the brightness option appears in the menu. @
whysoserious and @
mikeSiLVO cheers guys
4yrs and almost 2,000 replies...
Is it the end?
Nah
Aeon Nox: SiLVO is now available from the Kodi repository!
(2019-03-03, 21:25)mikeSiLVO Wrote: [ -> ]4yrs and almost 2,000 replies...
Is it the end?
Nah
And so the saga continues. I know that the future will be as great as the past has been. Kudos to the best Kodi skin there is!
My Kodi 18.1 just updated to Silvo 7.0.0. from the Kodi repository. Is there a way to download the 7.0.0 zip file? thank you.
I found the .zip. thanks for the update and putting the skin on the kodi repository.
Mine auto updated too. First time it's ever done it hands-off for me. Happy!
(2019-03-03, 21:25)mikeSiLVO Wrote: [ -> ]Aeon Nox: SiLVO is now available from the Kodi repository!
This is great news! I’m sure there’ll be many more happy users!
Nice to see that it's where it belongs to
Is it the end?
Nah
Yeah, excellent skin !!!
On a side note, I wonder if it is at all possible to randomize the background images to the main sections (Movies, TV Shows,etc) with images from a
given folder ? The setting doesn't seem to be there... Maybe a feature request ?
Keep up the fantastic work.
Cheers
(2019-03-04, 11:46)nanouk76 Wrote: [ -> ] (2019-03-03, 21:25)mikeSiLVO Wrote: [ -> ]4yrs and almost 2,000 replies...
Is it the end?
Nah [emoji14]
On a side note, I wonder if it is at all possible to randomize the background images to the main sections (Movies, TV Shows,etc) with images from a given folder ? The setting doesn't seem to be there... Maybe a feature request ?
Cheers
You can go into skin settings "setup the main menu" then "select Background" then select "Multi Image", but there are other choices to have random fanart as well. I use this method for a few of my main menu items.
Regards.
Bart..
