(2015-06-02, 22:04)mikesilvo164 Wrote: [ -> ] (2015-06-02, 21:55)motherboard Wrote: [ -> ]Hi thanks for getting back to me. I've got the option on the side menu to enable covers but they are not the blu ray covers as shown in your screens. Do I need to do something to change them?
Cheers
If your running one of the version of the skin from the first post then the cases will look different. There are still BluRay cases though. If you want the new ones pictured above on this page you have be on Isengard and download from GitHub.
I'll give isengaard a go. How to I get them on helix. I'm on the rightcase view but my covers just show little discs at the top
Cheers
Hi Mike.
Well download last github version and now works very well. Thanks. You've made a great job using bignoid version.
As you ask it earlier, i'd like you to keep the panel view on the tv shows please. Until the last past days i used the episode view, but now i prefer the panel one.
PS : Is it possible to use Schimik2k movie genre pictures in your skin ?
On GitHub do I download the master zip file. I'm getting dependencies not.met when I'm trying to install on Isengard. Never used GitHub before do any pointers would be great.
Man it would be good if someone could add the Banner Plex view in one of these skin mods. Best TV view ever was Banner Plex. Any chance of adding it into this mod at all ?
(2015-06-03, 07:47)motherboard Wrote: [ -> ] (2015-06-03, 10:49)motherboard Wrote: [ -> ]On GitHub do I download the master zip file. I'm getting dependencies not.met when I'm trying to install on Isengard. Never used GitHub before do any pointers would be great.
If you see the movie set case then you are most likely using a streaming addon... That's a limitation of using streaming addons. The cases populate based on the resolution info in the database when items are properly added to your library. If no resolution info is found the set box appears because if setup correctly that would be the only time that should appear. The only solution is to add the addon content to the library. I will not help with that as Google is the source of infinite knowledge and I also do not use any streaming addons.
master branch is for Isengard and helix branch is for Helix. Dependencies not met means you are most likely not installing the correct one for your version of Kodi or you are missing one of the required scripts.
(2015-06-03, 08:47)wilmans2m Wrote: [ -> ]Hi Mike.
As long as 1 person uses it I will keep it
You can add any folder with Genre fanart to the skin and set the path in Skin settings > Extras
(2015-06-03, 14:32)timoxx4 Wrote: [ -> ]Man it would be good if someone could add the Banner Plex view in one of these skin mods. Best TV view ever was Banner Plex. Any chance of adding it into this mod at all ?
Post a screenshot of what it looks like and I might add it.
(2015-06-03, 15:54)mikesilvo164 Wrote: [ -> ] (2015-06-03, 07:47)motherboard Wrote: [ -> ] (2015-06-03, 10:49)motherboard Wrote: [ -> ]On GitHub do I download the master zip file. I'm getting dependencies not.met when I'm trying to install on Isengard. Never used GitHub before do any pointers would be great.
As long as 1 person uses it I will keep it You can add any folder with Genre fanart to the skin and set the path in Skin settings > Extras
Hi no problem that explains it then. Regarding the Isengard master file it's strange as installs the scripts described in the first post but not the skin itself. Normally it asks if I would like to switch to that skin.
(2015-06-03, 16:01)motherboard Wrote: [ -> ]Hi no problem that explains it then. Regarding the Isengard master file it's strange as installs the scripts described in the first post but not the skin itself. Normally it asks if I would like to switch to that skin.
If you downloaded the Isengard beta from the main download page instead of a nightly then it might be the gui version. Update Kodi to the most recent nightly then see if you can install the skin without an error message. The nightlies should be more stable than the beta 1 download.
hi mike, great skin! I just updated to the latest version off github running on Isengard and spotted a bug. When looking at my movies in Showcase view, the case for non bluray movies (such as HDTV or HD-DVD) comes up correctly when the actual movie is selected, however when its not selected and it just one of the movies in the list, it doesn't show the real case, but a blu-ray one instead. Here is what it looks like:
watch gallery
As you can see, Catch Me If You Can is an HDTV file, and it shows the correct case. However when I'm not selecting it and selecting another movie instead such as Cast Away, then Catch Me If You Can (which is to the right of Cast Away) shows a Bluray case. Not an HDTV one.
This doesnt seem to affect the Set cases nor the DVD cases as they show up fine, but does affect HDTV and HD DVD. those are the only other ones I have in my collection.
hey mike please any chance that you can add clearart view
thanks
(2015-06-03, 16:37)gmantonz Wrote: [ -> ]hi mike, great skin! I just updated to the latest version off github running on Isengard and spotted a bug. When looking at my movies in Showcase view, the case for non bluray movies (such as HDTV or HD-DVD) comes up correctly when the actual movie is selected, however when its not selected and it just one of the movies in the list, it doesn't show the real case, but a blu-ray one instead. Here is what it looks like:
I believe I have fixed this. Thanks.
(2015-06-03, 16:51)mata7 Wrote: [ -> ]hey mike please any chance that you can add clearart view
thanks
I just added it as an option in Logo view but not for helix. Not sure if I will add it to Helix...
(2015-06-03, 19:08)mikesilvo164 Wrote: [ -> ] (2015-06-03, 16:37)gmantonz Wrote: [ -> ]hi mike, great skin! I just updated to the latest version off github running on Isengard and spotted a bug. When looking at my movies in Showcase view, the case for non bluray movies (such as HDTV or HD-DVD) comes up correctly when the actual movie is selected, however when its not selected and it just one of the movies in the list, it doesn't show the real case, but a blu-ray one instead. Here is what it looks like:
Ok, I just updated with the latest commits, and confirming that its fixed indeed, everything showing up properly now. Thanks for such a quick turnaround!
Please ignore/delete this post
(2015-06-03, 23:45)rebelone Wrote: [ -> ]Hi Mike,
Thank you for making this great mod. I think I spotted a bug.
I'm on your last commit on Isengard. With boxset mod enabled in Showcase, the watched indicator act strange. On select the watched icon disappears. When the boxset case opens you see the watched icon move like on a normal case. (behind the boxset art) This happens when all movies in de boxset are watched.
Also when boxset mod and clear covers are enabled, the boxset keeps there default covers on select. Left and right are clear covers as expected. If this is unclear I can make some screensshots.
Update from GitHub again. The last commit was about 3 hours ago. If problem still exists post a screenshot please. I just tried to replicate and I see a positioning issue where the Boxset watched icon needs to be moved up but nothing like you describe.
(2015-06-03, 23:45)rebelone Wrote: [ -> ]Please ignore/delete this post
I hope that means I fixed it already
I need bug reports. Even if I fixed them I'd rather have been told so I can test and doublecheck.
