Hey People,
Now I thought I create a submenu in the skin configuration in "MUSIC" with "Internetradio" as name and connect that with the (existing) source (stream links) on the Fritz!Box (UDP source). This also works fine. Even the fallback, for Discart with the current label (Edding replica *wink*) of the song from the stream works with appropriate skin. The Songtext works also, however, a cover / folder (in this case
not for an album, but for the Internet radio station can not be assigned. Also for each stream link the correkt Image (Folder) (
But how can I assign a cover / folder image to the stream (i.e. the radio station) ? On the Fritz!Box this is not possible, it only accepts URL's. About "Information" or music OSD I have unfortunately also found no possibility. Fanart I can assign via the skin setting. Maybe someone has an idea for this ? Many thanks in advance.
(2021-03-21, 18:41)pritt Wrote: [ -> ]Hey People,
Now I thought I create a submenu in the skin configuration in "MUSIC" with "Internetradio" as name and connect that with the (existing) source (stream links) on the Fritz!Box (UDP source). This also works fine. Even the fallback, for Discart with the current label (Edding replica *wink*) of the song from the stream works with appropriate skin. The Songtext works also, however, a cover / folder (in this case not for an album, but for the Internet radio station can not be assigned. Also for each stream link the correkt Image (Folder) ()
#EXTINF:-1 tvg-id="" tvg-name="|..X..| Channel" tvg-logo="http://..............png" group-title="......",|..X..| Channel
http://..............index.m3u8
Using Aeon Nox SiLVO on Kodi 19.0
Is conditional weather backgrounds working?
I can't find anyway to get it working on Kodi 19.0, works great on Kodi 18.9
(2021-03-22, 10:28)Jeffers24 Wrote: [ -> ]Using Aeon Nox SiLVO on Kodi 19.0
I use the Multi Weather addon. Remember you have to install the Weather addon. Then the option to select a conditional background will be available.
Note the Version of Kodi is 19
(2021-03-22, 10:28)Jeffers24 Wrote: [ -> ]I can't find anyway to get it working on Kodi 19.0, works great on Kodi 18.9
Hi...
To have conditional weather you have to:
1. Go to Skin Settings -> Customization -> Set Weather Background: download "Weather Fanart- Multi" and select it
2. Go to Skin Settings -> Main menu -> Setup the Aeon Nox main menu -> Weather -> Background: select "Conditional Weather"
That's it!
I have just installed an addon and viewed it in Estuary in "Programs/Addon name" where links in the addon have details about each link in a panel to the left of the links.
How can I get a similar view in Aeon Nox: SilVO so that details about links appear?
In Aeon Nox: SilVO the List view has just that, a list of the links without any details.
Can I view the addon links with a description of the link also viewable?
Thomfam
Not a good idea to be posting images containing all those
Banned Add-ons (wiki).
It means your post gets binned...
To display logos while "paused":
1. Skin Settings -> Video OSD -> Enable "Logo"
Additionally, you can access this options by Selecting "gears" icon while playing a video.
Note: On your second screen capture, you will not display "logo" because it's already displaying "clearart".
You can play with the settings display with the "Video OSD" options and select the best suits you.
(2021-03-22, 16:47)lynxstrike Wrote: [ -> ] (2021-03-22, 10:28)Jeffers24 Wrote: [ -> ]I can't find anyway to get it working on Kodi 19.0, works great on Kodi 18.9
Hi...
That's it!
Thanks for the step by step instructions, worked perfectly
Trakt watched indicators not showing at Movies and TV Shows levels.
Trakt watched indicators are showing at TV Show Series and Episodes levels.
Switched skin to Estuary, Trakt watched indicators are now showing at Movies and TV Shows levels.
Is this a skin issue?
Would someone check or advise me on how to fix at my end.
EDIT
Trakt watched indicators are showing in some views, for example they show in the 'List' view.
Maybe a skin+some views issue?
My post above details relate to the 'Info Wall' view.
(2021-03-23, 15:54)lynxstrike Wrote: [ -> ]To display logos while "paused":
Thanks but this is my point, in Aeon Nox 5, it would display the logo AND clearart, it looks a bit bare having just text for the show name when you're used to seeing the proper logo.
It makes no sense having logos if the skin only uses clearart when both are present (it displays both a poster and a logo in the show list so why not clearart and clearlogo on a pause screen?).
Also, with logo enabled on shows with a clearlogo image and NO clearart, the pause screen still shows no logo, so surely this is broken?
Alguien sabe porqué al crear widgets de ubicaciones de algun add-on en el menú principal algunos cargan y otros no?
Estoy en el skin Aeon Nox de Silvo para Kodi 18.9 para Android TV 10 y no he logrado que todos los widgets que he creado de Balandro de listas Filmaffinity por Productoras carguen correctamente.
Ayuda por favor.
Rafa3d
1 - This is an English-only forum. Use a translation service like Translate Google if necessary.
2 - Do not needlessly quote an entire opening post OR double-post your question(s).
