(2019-04-03, 23:31)bsoriano Wrote: [ -> ]@mikeSiLVO , I really like how in DialogVideoInfo in the skin you allow the user to select from searching the local library or showing extended info, when they click on an actor image. Would you mind if I adapt your code to use in the Amber for Leia skin I am working on? Please let me know. Thanks.
Regards,
Bart
That again is a BigNoid addition and I don't think either of us care if you use it
EDIT: Please give credit to BigNoid somewhere in the skin i.e. a credit, contributor, or wherever you deem appropriate.
If there is any other code you would like to use then as long as you have given credit to BigNoid or myself then feel free to use whatever you want. I, personally, do not care about credit so if you default to using BigNoid then that is A-OK with me
EDIT 2: This does not confirm any uses for code unless explicit permission is given by BigNoid or myself. No legalities are implied and without the aforementioned explicit permission from all parties involved it is not or should ever be inferred
My only issue is with these damn Build makers that piss me the F off... You get it.
He probably did all the cool (awesomely good) stuff anyway
(2019-04-04, 02:45)dkoh Wrote: [ -> ]Same thing. Crash (blank error) at the artist list.
https://pastebin.com/u20u3MfA
It is definitely a memory issue. A lot of folks use this skin with many different OS's and hardware so I just don't know why it works in other skins but crashes in mine. I cannot see a skin issue anywhere.
What I do see is this before you run out of memory:
2019-04-03 17:42:47.517 T:3776 DEBUG: Library Data Provider: Total time needed for all queries: 0:00:07.674000
2019-04-03 17:42:47.641 T:3792 DEBUG: CMusicDatabase::GetAlbumsByWhereJSON query: SELECT a1.*, album_artist.idArtist AS idArtist, artist.strArtist AS strArtist FROM (SELECT albumview.idAlbum, strAlbum, strReview, strGenres, strThemes, strMoods, strStyles, strType, strLabel, fRating, iYear, iTimesPlayed, dateAdded, art.url AS thumbnail FROM albumview LEFT JOIN art ON art.media_id = idAlbum AND art.media_type = 'album' AND art.type = 'thumb' WHERE albumview.strReleaseType = 'album' ORDER BY dateAdded DESC, albumview.idAlbum DESC LIMIT 20) AS a1 JOIN album_artist ON album_artist.idAlbum = a1.idAlbum JOIN artist ON artist.idArtist = album_artist.idArtist GROUP BY a1.idAlbum, album_artist.idArtist ORDER BY dateAdded DESC, a1.idAlbum DESC, album_artist.iOrder
2019-04-03 17:42:47.841 T:3956 DEBUG: Thread BackgroundLoader start, auto delete: false
2019-04-03 17:42:47.862 T:3832 DEBUG: ffmpeg[EF8]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2019-04-03 17:42:47.865 T:3712 ERROR: CImageLoader::DoWork - Direct texture file loading failed for special://masterprofile/Thumbnails/8/83102a58.jpg
2019-04-03 17:42:48.040 T:3712 DEBUG: Caching image 'smb://MACHINE01/E/#Artist Info/'77/fanart.jpg' to '8/83102a58.jpg':
2019-04-03 17:42:48.040 T:3712 DEBUG: cached image 'special://masterprofile/Thumbnails/8/83102a58.jpg' size 1920x1080
2019-04-03 17:42:48.580 T:3792 DEBUG: CMusicDatabase::GetAlbumsByWhereJSON - query took 940 ms
2019-04-03 17:42:48.598 T:3832 DEBUG: ffmpeg[EF8]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2019-04-03 17:42:48.609 T:3792 DEBUG: Skin Widgets: Total time needed to request recent items queries: 0:00:01.133000
2019-04-03 17:42:48.610 T:3792 DEBUG: Skin Widgets: Total time needed for all queries: 0:00:08.512000
2019-04-03 17:42:49.801 T:3956 DEBUG: Thread BackgroundLoader 3956 terminating
2019-04-03 17:42:49.837 T:3584 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
2019-04-03 17:42:49.837 T:3584 DEBUG: CInputManager::HandleKey: right (0xf083) pressed, action is Right
2019-04-03 17:42:49.930 T:3712 DEBUG: ffmpeg[E80]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2019-04-03 17:42:50.004 T:3584 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
2019-04-03 17:42:50.388 T:3584 DEBUG: Previous line repeats 1 times.
2019-04-03 17:42:50.388 T:3584 DEBUG: CInputManager::HandleKey: right (0xf083) pressed, action is Right
2019-04-03 17:42:50.474 T:3732 ERROR: CImageLoader::DoWork - Direct texture file loading failed for special://masterprofile/Thumbnails/8/8f0c1806.jpg
Perhaps there is some issue with either Library Data Provider, Skin Widgets, or the library database itself but I really have no idea
The only thing that I probably do differently is using the new Music Information folder and fadelabels to display fanart1, fanart2, ect...
When you have debug logging on what is happening with the memory allocation and where does it "start" to max out? On load of MyMusicNav (music section of Kodi) or just after scrolling for a bit? What view is this happening with? Every view or just one? Does disabling extrafanart fix the issue?
What happens if you delete every addon in your Kodi addons folder besides skin.aeon.nox.silvo? Same issue?
DaveBlake @
rmrector do you guys have any idea what is happening here?
(2019-04-04, 06:49)satelly Wrote: [ -> ]quick question. have been using this excellent skin for a while on one of my setup. i have some videos that are not scanned into the library eg. home videos. i create own fanart and poster jpeg for these and they work fine. recently i changed the fanart and i understand kodi usually scans every ?few days and updates it. on my other media box running arctic zephyr, it updates but the old fanart still hasn't changed on the media box with aeon nox: silvo.
any suggestions.
thanks
Sounds like a cache issue. You may need to change it manually using the choose artwork button in the Video Info screen or using a utility like Texture Cache Maintenance Utility or Artwork Beef.
(2019-04-04, 07:14)sirius1979black Wrote: [ -> ]Mike
Got to say this is the best skin IV ever used got everything u ever need ..... AWESOME Job
Only thing is my sub menus don't open to the correct place only opens the add-on the shortcuts are in
Can you please have a look at this , Thanks
By the way version 5.9.4 skin.aeon.nox.silvo" version="6000.0.3" name="Aeon Nox 5: Question Mark
Well my skin has never had a 5.9.4 version number but OG Aeon Nox 5 has and this bit
version="6000.0.3" name="Aeon Nox 5: Question Mark looks like a stupid build that is not supported cause I would have no idea what was altered in the skin.
(2019-04-06, 12:06)Solo0815 Wrote: [ -> ]Fix for PVR remaining time:
https://github.com/mikesilvo164/Aeon-Nox-SiLVO/pull/86
Bug:
TVShows -> TVShow Fanart for unwatched items isn't working anymore. It just shows the default video PNG. Watched items show the episodepreview thumb.
It should look like this: https://forum.kodi.tv/showthread.php?tid...pid2721904
That PR has over a thousand lines of code changes so will not be merged cause it is too difficult to check all of them. I will edit the demo client to show a 61-69 minute "episode" and try to see where the variable is "messing up".
I just tested hiding episode thumbs and it is working exactly as expected in all episode views using v18.1 final. Where do you see it not working?
EDIT 3: If you say it is a problem with your damn Vitameatavegamin then we gonna have to throwdown...
