(2021-01-24, 02:19)Thomfam Wrote: [ -> ]Thanks for your response flhthemi. I am using Kodi with the Aeon Nox Silvio skin to play back my Plex library. I am using the addon Composite to access my Plex and when I long press or hit "C" for the context menu I get a range of options but nothing like what your examples are showing me. The option to Edit titles, delete files etc are not available. I get a whole string of options such as Refresh Library, Mark as watched, Play Transcoded, Mark as unwatched, Add to Playlist, Information, and many more but nothing about deleting a file. It is possible a "Composite" addon problem so I may head to their forum and post my hassle there. Thanks ..... unless someone else is using Composite with this skin and has worked out how to delete files.
I am getting ready for the movie to Kodi Matrix. I have my setup working well using Composite with my Kodi 18.9 and I have previously used the highly configurable Xonfluence skin.
However it doesn't seem likely Xonfluence will be upgraded to work with the new Kodi. So I am trying the Aeon Nox Silvio skin which I have set up on Kodi 18.9 with Composite working fine ... except for the context menu to show to delete a file from my Plex. I have allowed the option to show hidden files and to allow deleting of files in Kodi. In Aeon Nox Silvio I can bring up the context menu but the option to delete a file isn't available despite deleting of files being enabled as I can when using Xonfluence.
Has anyone got deleting of files working in Composite and uses the Aeon Nox Silvio skin? I have set up the Plex Kodi addon on the same version of Kodi and the Aeon Nox Silvio skin, signed in etc and can delete files from the Plex Addon easily via the context menu.
I've ensured I have logged into my Plex Account via Composite, I have set the Server (all via Composite "Settings"). I have restarted Kodi and gone to a file and 'long pressed' to get the Context Menu and I get Play Transcoded, Mark as watched, Mark as unwatched, Add to playlist, Audio, Subtitles, Update Library, Refresh, Play, Information, Mark as unwatched and Add to favourites. But there isn't the option to Delete.
It's as if I have signed into Plex via Composite but it isn't recognizing me as the Server Owner and therefore able delete files. Note this happens with the skin Aeon Nox Silvio. The delete option in Composite works fine if I'm using the Xonfluence skin. The problem only occurs when using Aeon Nox Silvio.
(2021-01-25, 03:34)Thomfam Wrote: [ -> ] (2021-01-24, 02:19)Thomfam Wrote: [ -> ]Thanks for your response flhthemi. I am using Kodi with the Aeon Nox Silvio skin to play back my Plex library. I am using the addon Composite to access my Plex and when I long press or hit "C" for the context menu I get a range of options but nothing like what your examples are showing me. The option to Edit titles, delete files etc are not available. I get a whole string of options such as Refresh Library, Mark as watched, Play Transcoded, Mark as unwatched, Add to Playlist, Information, and many more but nothing about deleting a file. It is possible a "Composite" addon problem so I may head to their forum and post my hassle there. Thanks ..... unless someone else is using Composite with this skin and has worked out how to delete files.
All my own fault, In Composite I went to Settings, Look and Feel and there, way down at the foot of the menu was "Show delete in the context menu" and then hit Save. All sorted!
Once again, I am asking for help. Maybe someone will help me now.
I would like to add a button on the "MusicOSD.xml" toolbar that redirects directly to skin 1 or 2 lu3 etc.
I mean - normally the button to change the skin looks like:
<onclick> Dialog.Close (musicosd) </onclick>
<onclick> ActivateWindow (1120) </onclick>
<onclick> SetProperty (MusicOSD.Settings, True, Home) </onclick>
I need to be redirected directly to the skin (Music Layout aligment) Center or Left or Test Layout ....
Please help me. Thank you
Hi mikeSiLVO
I need a little help. I noticed that the intro of kodi is cutted during the fist start of Kodi. The intro goes until the end after restart Kodi. Does it as a certain time to load the intro?
Do you have an idea?
I have Kodi 18.9 and I use Xampp (appache and MySQL) for my libraries on Windows 10
Not sure if this is something that is possible, but thought I'd ask.
I've got a menu entry named PERSONAL, which links to family videos, and rotates personal pics as the background. In some skins, it resizes the pics to fit the screen, either horizontally or vertically, while others (Aeon Nox) squeezes and stretches (distorts) the images to fill the screen.
In SiLVO, however, the pics are displayed as is.
So, my query... is there a setting that can be changed, so that it will fit the pics on the screen (non-distorted)?
Here's an example of how it looks now.
(2021-02-12, 06:00)RobbieWilkes Wrote: [ -> ]So, my query... is there a setting that can be changed, so that it will fit the pics on the screen (non-distorted)?
No, there is no setting. You need to edit the skin files. If memory serves me right, you want to search for these tags, and change the value to
keep
xml:
<aspectratio>keep</aspectratio>
Nobody can help me solve the problem?
An issue in Matrix.... In the Dialog Addons buttons. Addons/Info page theres no "Update" button or in Matrix its called "Versions" now. To be clear, im talking about the info page when you click info on an addon in the addon browser. Other buttons there are Open, Configure, auto update, Disable, uninstall etc.
I've been tinkering with some mods to menu items for Aeon Nox: SiLVO, and it's coming along nicely, I appreciate all the posts on the forum.
I'm trying to reduce the size of posters in the MyFlix view so that more posters can be added to the screen (currently 7 posters is default). I've managed to mostly reduce the size of the posters themselves, but they're spaced apart using the settings from the original size. How do I move them closer together and add more posters to fill the screen?
Once I get this figured out, I'm going to try to increase the size of the info panel to display a bit more of the plot as well. If anyone has tips on this, I'm all ears - thanks!
(2020-10-30, 00:38)guandms Wrote: [ -> ]Hi All,
I would really like your help with the Music artist Logo, this is the only fanart that is missing from my library.
I went over the configuration and I'm using Silvo for a few years now, but I had to reset it because I changed my NAS and had to start all over again.
All of the fanart for TV Shows and Music is working except the Artist logo which is weird, I have a folder that I configured in the Skin settings that contains all of the Artists logos as I always have but now it doesn't show it for any artists and I would really like to solve it...
Thanks you.
Having the same issues since I switched to Shield/Matrix RC1.
No artist logos are displayed.
Artist slideshow works, cdart and album art are displayed just fine but no artist logos ;_;
(yes, logo is switched on in menu/OSD)
Hello there!
Guys, can anybody explain is it possible to modify the power menu layout (the one which opens on ESC or RS button) in this skin to add an minimize option, for example?
(2021-02-16, 12:01)Landxhent Wrote: [ -> ]Hello there!
Yes, you can.
Edit xml file "
DialogButtonMenu", located at:
C:\Users\YOUR_NAME_HERE\AppData\Roaming\Kodi\addons\skin.aeon.nox.silvo\16x9
There you can add or delete options as you see fit.
(2021-02-16, 16:46)lynxstrike Wrote: [ -> ] (2021-02-16, 12:01)Landxhent Wrote: [ -> ]Hello there!
Yes, you can.
Edit xml file "DialogButtonMenu", located at:
Thank you! Now i only need to fit it within the menu and rename accordingly xD
I would like to add the RightList view when a Music Video is in focus.
Currently the Music Video menu only offers the options: 'List', 'ShowCase', 'Shift', 'Posters', and 'Icons', whereas the Music menu offers: 'List', 'SongList', 'RightList', 'LowList', Shift, ShowCase', 'TriPanel', and 'Icons'.
I have tried editing Kodi\addons\skin.aeon.nox.silvo\16x9\View_506_RightList.xml to add 'musicvideos' where 'music' appeared, but this hasn't worked.
Grateful for any suggestions.
Shift view doesnt have ''Logo Art'' option to display below the deck ? Kindly add .
Kodi Flix doesn't have onscreen Logo art or clear art , rating etc ?
