Hi all,
I love to use the logo view, but I realized that I don’t have reflections in the status bar for the logos. What did I mess up, anyone knows that what’s missing?
(2021-09-10, 10:32)HussainJH Wrote: [ -> ]Hi
I can't fetch clearlogo for Nine Perfect Stranger from fanart.tv
How to fix that ?
You can download manually and add the file through the menu. That could be the movie data provider addon issue.
(2021-09-09, 21:06)justin150 Wrote: [ -> ]For some reason when I set my widget to display the movie sets I have in my movie library, the widget info panel does not seem to display all the right information. For completeness my movie library is set to use local info only as I have a nfo file for every movie
There are 2 issues (the second one may be an info provider issue not a skin problem)
1. It should show the number of movies in the set, I have checked the xmls and there is a line in variables_widget.xml to provide the information:
The HomeWidgetInfoSubTitleVar has a value condition
<value condition="!String.IsEmpty(Window(Home).Property(SkinInfo.Set.Movies.Count))">$INFO[Window(Home).Property(SkinInfo.Set.Movies.Count),, $LOCALIZE[342]]</value>
But it is not picking up anything.
2. what I would like the info panel to display for ratings is the same as for a movie - namely Ratings & Votes but ListItem.RatingandVotes for sets does not pick up that info.
I am comfortable amending up the XMLs but feel I am missing something very obvious. Can anyone enlighten me as to why I am not seeing the right information
OK lots of digging through XMLs, google searches and a couple of other things and I think I have isolated the problem of the missing information about number of movie movies in a movie set. I think the problem is that Silvio is calling in a number of places for SkinInfo specifically the script.skin.info.service which does seem to exist in K19 Silvio. I have a bad fix which is to download script.skin.helper.service and then amend up the variable-widget xml so that the relevant value condition points to SkinHelper.ListItem.Count but ideally I would prefer to use TMDB Helper (I have looked at Embuary Helper but it does not deliver enough info about sets as far as I can tell). This is where my knowledge runs out.
It looks to me (which almost certainly means I am wrong!!) that the coding of the Silvio xmls where it refers back to script.skin.info.service may now be out of date. Could anyone who has a lot more skill and understanding than I do have a look and see whether I am on the right track - it may be something that needs to be amended in the next version of the skin
(2021-09-02, 15:07)mikeSiLVO Wrote: [ -> ] (2021-09-01, 09:57)Jeffers24 Wrote: [ -> ]When I play locally stored music CDs or MP3s for example, Kodi 19.1 isn't switching to full screen.
All works well in Kodi 18.9, so I compared my skin settings and found that the 'Autoplay music in full screen' setting is not available as an option in the Kodi 19.1 skin settings.
Could this be the cause of music not playing in full screen, is there a way I can get music to play in full screen?
Music is playing full screen when I play a radio station from the 'Radio' addon from the Kodi repo.
Screenshot below shows the setting option in Kodi 18.9, which isn't present in the Kodi19.1 version of the skin.
It was removed for Kodi v19 because its a system setting now so I don't need to use the "hack" workaround
Sorry if this has been asked before (based on the original post topic), but this thread is almost 700 pages: Is there a known issue with the intro not working on LibreELEC 10.0 (stable) with Aeon Nox: Silvo? It seems to run audio only (with black screen)
(2021-08-14, 16:04)Vibes Wrote: [ -> ]Anyone know where I can remove the so called "System bar" (marked in red) completely? I see an option to move it to the top in skin settings but how do i disable it? Thanks
Open Includes_Home.xml in folder skin.aeon.nox.silvo\16x9 and comment the block of code starting with line <include name="HorizontalMenuSystemBars"> (lines 89-227)
(2021-08-30, 20:24)dpar Wrote: [ -> ]Curious if anyone has done any modifications for showing a Dolby Vision flag with Aeon Nox Silvo? It didn't used to matter but I'm getting more DV content. For my main Windows htpc it doesn't generally matter since it doesn't support DV and plays the content in HDR instead. But for my android box it would be nice to know what supports DV and what doesn't. Even if just in the Info screen it would be nice to have a Dolby Vision flag to denote support for it.
mikeSiLVO Any thought to having a Dolby Vision "dv" tag to note that content vs other HDR formats?
Could someone point me in the direction of the correct file(s) that implement the TV Guide? I used to apply a custom version of "Includes_LiveTV_Views.xml" to Aeon Nox to make the guide more to my liking (playing show in a window on the top right, selected show info on top left, guide text wrapping to a second line so more info can be read...), but Silvo appears to skin the guide in a different location.
(2021-08-10, 15:10)flhthemi Wrote: [ -> ] (2021-08-10, 09:52)Jeffers24 Wrote: [ -> ]My phone has updated to Android 10.
I did a clean install of Kodi 19.1 and installed the Aeon Nox SiLVO skin from the Kodi repo.
Now Kodi or Skin isn't working.
When I run Kodi skin loads okay and the Movies option is in the centre of the screen, seems okay.
However if I scroll the menu items so System is now in the centre and select it the options displayed are the Movie menu item options, not the System options.
It's the same for all the main menu items whichever one I select I get the Movie options displayed. Kodi or the Skin is staying focused on the Movies menu option.
As well as the main menu item staying focused on the Movies option the sub menu items also stay focused on the Movie sub menu items, see screenshot.
I am unable to select the Power menu options and select Exit.
I don't get any Kodi errors.
Anyone any ideas how I can fix this?
EDIT - Kodi 18.9 with Aeon Nox SiLVO is working perfectly on my phone
If I recall correctly this is a bug in Kodi 19.1. If and when 19.2 gets released it's supposed to be fixed. I reported this, in this thread, a while back and even supplied a video of the issue. It's not only android. I have a Windows laptop with a touch screen and the same thing happens on it if I touch the screen. Keyboard and mouse work fine. I can't upgrade to 19 until this is fixed. So I hope 19.2 cures the situation.
Change skin with Amber for touch device
(2021-09-17, 12:18)audiosistem Wrote: [ -> ] (2021-08-10, 15:10)flhthemi Wrote: [ -> ] (2021-08-10, 09:52)Jeffers24 Wrote: [ -> ]My phone has updated to Android 10.
Being the stubborn old man I am....I won't change skins as NONE of the others are as good as this one is!
LibreELEC (Matrix) 10.0.0
I can't install this skin (from the .zip file or the repository).
Is there any way?
Libreelec worked great on the previous version.
Hello to all.... I got a problem with my Kodi (Libreelec 19.1 RPi4B/ skin Aeon Nox) when i scroll through videos. The screen turns black and sometimes it stuck.I use movie set artwork if that is the problem? I have looked in the log and can see that is the "Studio White - Icons" that create the problem. I have tried to inactivate it with no luck, neither can i uninstall it though it is needed by Aeon Nox... Please help me
(2021-09-19, 13:45)Kuba01 Wrote: [ -> ]Is there any way?
You can try to unzip the skin and copy "skin.aeon.nox.silvo" folder to:
C:\Users\your_name_here\AppData\Roaming\Kodi\addons
Afterwards, go to "Settings", "Addons", "My Addons", "Look and Feel", "Skins" and choos "Aeon Nox Silvo". Enable it!
Thats all...
Hope this works...
Regards,
(2021-09-20, 07:18)2469 Wrote: [ -> ]"Studio White - Icons" that create the problem
You can try to manually delete the add-on and afterwards re-install it.
Go to:
C:\Users\Your_Name_Here\AppData\Roaming\Kodi\addons
and delete the folder named "resource.images.studios.white"
... then just reinstall directly from Kodi repository...
Hope this works...
Regards,
Is the procedure the same at Raspberry pi 4B except for the adress?
