Hi All
i guess this is a very stupid question on this forum but here we go
Currently my OSD Player buttons are set to show at the button and I am trying to move the OSD Player Buttons just a lit bit up so it does not overlap with subtitles, I was trying to find the XML file to change the position but nothing
anybody knows which file and parameter define the OSD Player Buttons position?
Tks in advance
(2022-03-12, 16:40)CoyoteLoco Wrote: [ -> ]Hi All
Tks in advance
You can easily move the OSDs for video and music to the top in skin settings, see screen shot.
https://imgur.com/oU43Dm6
take a look at the screenshot
the OSD Buttons are on top of the subtitles, I know I can move them to the Top of the screen but if I can move the current bar just a little bit UP will be great
OSD Buttons
(2022-03-12, 17:12)CoyoteLoco Wrote: [ -> ]take a look at the screenshot
the OSD Buttons are on top of the subtitles, I know I can move them to the Top of the screen but if I can move the current bar just a little bit UP will be greatOSD Buttons
I see what you mean, I think that would be a mod to the skin code.
I never do skin code mods, as they would be overwritten by the next skin update.
Would it not be easier to move the subtitles up using the settings for where they appear on screen?
yeah that is possible but then the subtitles will be very very high on the screen
I cant find LIVE TV in the menu bar. Cant seem to find it in the configuration either. Am I missing something here?
Kind regards,
(2022-03-14, 22:56)gotham2014 Wrote: [ -> ]I cant find LIVE TV in the menu bar
Do you have a Live TV backend installed and configured?
See...
https://kodi.wiki/view/PVR
Hey Guys, having one of those at a loss moments.
Doing a clean rebuild and have come across this. I have my movies set to show only unwatched, I use the Recently added Widget, once a movie is watched it no longer appears in the widget. At least that is how it worked for ages, on this fresh build the widget pulls all recently added including watch and unwatched.
I know is will be something simple, any ideas
Never mind, I used the recent movies widget and that worked...
Does anyone know which code file contains the Home Screen art slideshow please?
I noticed when on the Music menu node the skin fanart slideshow is not random or even seems to find most the artists at all. I have 300 odd artists but the fanart slideshow was cycling through the same (about) 20 only, over and over.
Second issue is it attempts to show an artist image even if there is none for that artist. It just shows a blank background with the artist name at bottom left of screen. It should skip artists without a fanart image.
I’d like to have a go at fixing both these issues.
THX
Garry
how can I set a SINGLE background image for the main menu items? like movies, music etc? does the skin gives us images? I don't want to use from external storage photos!
(2022-03-25, 01:06)fuorigioco1981 Wrote: [ -> ]how can I set a SINGLE background image for the main menu items? like movies, music etc? does the skin gives us images? I don't want to use from external storage photos!
Skin Settings>General>Set Default Background
When selected you'll have an option of "Set Single Image Background" or "Set Multi-Image Background". Selecting either will display a few images that are included with the skin. However, keep in mind you do not have to use "external storage". You can use your own images by copying them into the same folder as these default background images OR you can create a folder in your Kodi user folder for backgrounds and copy them there. I have done the later and named the folder "Backgrounds".
Aeon Nox Silvo's default background folder on Windows is "\Users\username\AppData\Roaming\Kodi\addons\skin.aeon.nox.silvo\backgrounds"
Hi @
Karellen
Yes, all is working fine if I switch to the KODI default skin. But when I go back to this skin, I cant find the LIVE TV menu anywhere anymore. Its like it has not been added to the skin. The PVR settings are also accessible in the Kodi settings for my NextPVR client.
How to enable the LIVE TV menu in this skin?
so can you go into skin settings , configure main menu , then press + and add live tv as a menu item.
