(2024-01-16, 23:36)voot Wrote: [ -> ]Yes, I use most current Git version (for Omega).
Movies - duration:
Are you absolutely sure that you are using the latest from Git?
Quote:Are you absolutely sure that you are using the latest from Git?
I think so... but I see that it looks better in your case.
Tomorrow I will install everything again to be 101% sure.
(2024-01-16, 23:56)voot Wrote: [ -> ]Quote:Are you absolutely sure that you are using the latest from Git?
The latest, up-to-date Git version, untouched (for Omega).
https://imgur.com/a/VHylcSf
(2024-01-17, 10:13)voot Wrote: [ -> ]The latest, up-to-date Git version, untouched (for Omega).
I tested on Matrix and Omega using Windows and Android. No issues.
Unless someone else says they have the same issue I have to assume some kind of user error.
How can I change the interpunct ⟨·⟩ between weather and date to | in the topbar?
It should be like between the date and the time. See the Screenshot
I am trying to understand where to "put my hands" into the Rightlist view in order to change a few things more to my liking.
I suppose the file to edit would be View_506_RightList.xml. Is that correct?
Where is the code handling the dimmer setting located? I would like for the dim to be applied to only the right portion of the screen, fading out quickly once it "exits" the text in the list (movies, episodes, music tracks, etc.). I can try to understand how that works but not until I find where it's handled.
Last question: where in the code is the "highlighting" of the selected entry handled? I refer to the movie title, episode title, track title, etc.
I am not sure if this kind of questions is accepted or well received. In case it isn't or it's deemed to be a waste of time, sorry in advance.
(2024-01-17, 19:24)mikeSiLVO Wrote: [ -> ] (2024-01-17, 10:13)voot Wrote: [ -> ]https://imgur.com/a/VHylcSf
I managed to solve this problem: in Includes_DialogInfo I increased from <width max="140"> to <width max="141">.
Everything is ok now.
Hi @all
Thank you MikeSiLVO for your dedication.
I'm missing some info's. Kodi Nexus 20.2 and 20.3, Skin Version 9.1.1
- the Status/Next Aired info is no longer showing up (MyFlix view, tv shows, smart playlist)
- the playliststatistics (not library statistics) for the moviesplaylist and tv shows playlist are no longer showing at the top in the main menu (xy shows/movies xy watched xy unwatched xy etc)
Kodi Nexus 20.2 and 20.3, Skin Version 9.1.1, with 9.0.1 its working.
It seems Nexus 20.3 has changed something when "show video info" is the default selection behaviour chosen in the video library settings. In 20.2 and earlier, if there was no metadata the selected video file would simply play but in 20.3 it displays a "No Info" dialog. This isn't great for me because I have folders of video files that are not in the database and don't/never will have metadata (for example Dolby test files) that I have set up a shortcut in the menu to display the folder in List View so I can quickly play them.
Is there any way in the Aeon Nox Silvo skin to override the default select behaviour for a specific view or menu item? it would be a useful customisation for me if it could be done.
Hi Mike
maybe you'll know what's going on ?
I have some videos added to the AutoWidget list
I add a list to Widgets on the main screen, when I want to play a video from the home screen widget kodi closes and I have a crash log. A video played directly from the AutoWidget plays correctly.
I've noticed that if I change the video in Autowidget filetype:file to filetype:directory, then I can play it correctly under the addition as a Home Screen Widget.
Got an issue where when I set a custom background for a menu item, it displays fine at first, but then after a while seems to switch to a lo-res version. I'm using OSMC, and the images are being stored locally. Any idea what's happening?
Please help.
kodi 20.3
Since the last updates my favorites did not work.
I changed it the right way but now I just get a black screen and all I can do is to end Kodi and start a new because I can't get out of these favorites
Kodi not stop working means I hear sound when I try to get out of that window but no chance.
I so not want to make all settings new so any help please?
Does anyone know how to stop Aeon Nox Silvo from taking control of other windows and bringing them to it's monitor?
I am running Pop_OS (with a dual monitor set up) - when I start playing a video with Aeon Nox Silvo (in full screen mode) it grabs other windows (like Web Browser) and drags them to same monitor as the one Kodi is in. Other skins don't do this and I would like to disable this feature.
(2024-01-04, 17:12)lynxstrike Wrote: [ -> ] (2024-01-03, 23:06)skullmonkey Wrote: [ -> ]Does anyone else lost Favorites window after the last update?
It's not working for me either.
Did you manage to fix this? Lots of time is wasted finding what im watching mostly.
tnx
